Tonight I took it out after replacing yet another servo and It seemed to not want to throttle right. It would for a bit and then it would do nothing. I thought I should check my connections and all were good. I turned it on and the light was fast blinking red (on the receiver) and no throttle/brake, but I had tons of steering. Fast as heck. The pack battery just was charged and new batts in the transmitter just before I took it out. Messed with it for a bit and all of a sudden my green light was on. But.... after turning it back on my th/br servo was now reversed. Why did this happen? I went and reversed it back to normal and now my throttle settings are off and it is running really high because the servo is holding the carb open a little. I loosened the lock slider and readjusted it just so I could run a tank thru it and now it only has 3/4 throttle. It is like it lost all my settings after it reversed itself. I can fix this again but I just do not understand why it keeps reversing itself (and only the thr/bra servo) never the steering.
