Long story short, the remote control took a spill Sunday, spilt the batteries every where, lost a couple battery springs, and broke the antenna. I put new batteries in it, robbed some battery springs from another remote, and borrowed my e-maxx remote control antenna. I put it all back together and it appeared to work.
Problem:
I noticed a small problem, yet a problem non the less! I went to lock the front only, NADA! Yet when I went to lock both, it locked both just fine with no hesitation. I took the body off of the summit and looked as I went through all of the shifting, and noticed when I go to lock the front only it does nothing (no sounds, no partial moves, nothing). I took the r/c apart and looked inside to see if it was damaged from the fall, and everything look good except for piece of plastic that helps guide the antenna down in it (no biggie). I didn't notice any lose wires, any lose internal parts, and the stuff that is mounted to the locker switch looked good.
What should I take a second look at that maybe I over looked? Like I said, it's a livable problem, but it would be nice to keep the r/c car working like new!
