+ Reply to Thread
Results 1 to 13 of 13
    Jun 2006
    RC WORLD
    569
    steel shafts popping out of drive cup
    i have installed and broke many plastic shafts and finally got fed up with them so i purchased the Traxxas steel cvd shafts.
    all seemed great i drove it for about 30 minutes and then noticed it was front wheel drive only again....
    I looked under the truck and noticed the right rear shaft had popped out of the drive cup at the wheel.
    for the life of me i couldn't get it back in with out totally distorting and wrecking something .. i had to disassemble the one a-arm to get it back in. i couldn't figure out how it came out in the first place...
    and thoughts?
    running on 4s 8000 each batts
    E-REVO brushless ROCKS!!
    Apr 2007
    Winnipeg, Manitoba the Slurpee Capital of the World
    805
    As stated in the instructions, they cannot be used with your pushrods in the innermost hole or with the long travel rockers. If you are using the extended rear a arms you need the extended drive cups.
    if you dont break something go higher and faster
    188
    having your slipper clutch set to where it will slip a bit on a hard pull on asphalt will make your driveshafts last much longer.
    Jun 2008
    Winnipeg, Canada
    1,048
    You need to use p# 5153R then you can run on the innermost hole. A bad cartwheel could release the shaft, but other then that its fairly reliable.
    MBX5T|MMM/2200kv|16/46|Hitec 7955TG|KingHeadz
    Apr 2010
    8
    if you got rpm arms can it maby pob out because they are more flexibil then the std arms
    Oct 2008
    Soldotna, Alaska
    676
    definately get the extended drive cups. the a arms can flex, and rpm arms flex even more, and this can allow it to pop out of the cup. i run rpm arms, extended cups, and middle holes. Its easy to put them back in anyway. just unscrew the upper pillow ball, put the driveshaft back in, and rescrew the pillow ball.
    Using while stupid may cause serious injury.
    May 2006
    Sacramento CA
    158
    I had the same problem. Have your pushrods moved to the inner or second/middle position. You might have too much suspension travel. I believe it says it in the manual. I did this fix and never again they popped out.
    Revo.28 http://www.youtube.com/watch?v=Dscu3-a3DX0
    152
    what are the best driveshafts, i just broke another one
    http://i1016.photobucket.com/albums/.../Photo0355.jpg
    Please keep images to 640x480 or smaller.
    -Carraig042
    Jun 2009
    W Monroe, Louisiana
    1,972
    how did you break that!!?? It looks like both sides are still intact.
    I can make it easier for you. Either summit shafts or traxxas steel cvds.
    FYI Ebay had the best Summit shaft prices for 45 shipped for all four.
    152
    lol i was just popping wheelies, my wheelie bar kept popping out, next thing i know this. both sides are still good
    Jun 2006
    RC WORLD
    569
    what if i took my welder and put a tiny weld blob on the cup preventing the shaft from popping out not hampering the movement of the shaft in the cup though
    Marshal carraig042's Avatar
    East Tennessee
    6,645
    You might cause the shaft to bind which could bend it. Just get the extended cups, they are your best bet.
    -Brett
    4wd Sportmaxx 3.3
    Registered User majestic's Avatar
    Mar 2006
    Plain'ol Texas
    553
    Also make sure the pivot balls are screwed into the arms until the threads are not visible. This isn't a issue when the telescoping driveshafts are used but can be when using CVD's.
