Results 1 to 11 of 11
    Apr 2010
    Townsville, Australia
    629
    a thought for dual dewalts
    i just had an idea and it might work
    run dual dewalt 18v motors in the summit
    also use 25.2 volt lipos
    now for an esc that will handle it. will the mamba monster let you run brushed motors or only brushless?
    why this idea.
    why not.
    it will keep it waterproof and its a different idea then everyone else going nuts with brushless motors.just need to to water proof the mamba monster.thats doable, get that info from google
    i read on another forum you can grab a stock erevo motor plate - part #5690
    add this to your summit tranny and whack an extra motor in it and it all stays covered up so no dirt etc gets in to your gears
    food for thought
    Aug 2009
    Spruce Grove, Alberta
    1,552
    yes the MMM esc will run brushed motors, but you might need a cat battery to run dual dewalts. how would you wire 2 motors to the MMM esc?
    http://traxxas.com/forums/showthread.php?536733
    Jan 2007
    regina sask, canada
    2,344
    couldn`t you just go say positive wire to positive on motor then negative motor wire to postive on other motor and negative on the there side
    if your not breaking anything get more air
    Aug 2009
    1,552
    that would be running in series so it would split the voltage, between the 2|(I think). I think you would have to run parallel, to get the 25 volts to each motor. tap 2 positives and 2 negatives off the esc and run to each motor. I could be wrong though
    Apr 2010
    629
    Quote Originally Posted by quadiak
    easy
    make a y cable
    so you have 2 wires joined together that feed in to the MMM esc
    cos you now have dual positive/neg cables run one set of wires to each motor
    you do the same thing now with the stock traxxas esc to run dual 700 ho motors from kershaw
    so in this case you just need to make your own y cable to fit the motors to the mmm
    this way it is wired in parallel, you get the full 25.2 volt from the lipos and th 18v motors will get some serious power shoved down their neck!
    Aug 2009
    1,552
    Quote Originally Posted by stinger30
    easy
    make a y cable
    Here is the problem. http://monster.traxxas.com/showthread.php?t=519182
    Sep 2009
    3,127
    with all of this - if ya gonna run the mamba esc you should run the mamba motor as well - more power, more speed and MUCH greater effiency (mamba motor $100 , 2 dewalt 18 volts $72). Why step up to a mamba then step down to brushed motors? Unless its just for the sense of "project CAN-DO"? but know a dual dewalt set up will not much faster than a single dewalt set up, just more grunt and MUCH lower run times.
    MAN, Use Common Sense.
    Outside? THERE IS NO BOX !
    Apr 2010
    629
    Quote Originally Posted by noir522
    it was an idea....i didnt say i was going to do it
    im not looking for blistering speed....if i wanted that i would mount a rocket to the summit instead
    just thinking out side the square....i still reckon it would be a cool thing to do with plenty of torque...just for fun
    Aug 2009
    1,552
    Certainly nothing wrong with thinkin outside the bun( ), I do a fair share of that myself, lol. still working on funding my next attempt at waterproof power hop ups.
    Jan 2010
    west palm beach, florida
    548
    email kershaw he told me he made a dual dewalt mount I didn't want to run 2 motors for run time so I passed. I'd say mmm and 2 3s in series (6s) and run a split wire to both motors
    Oceanside, Ca
    25
    I saw youtube on dewalt summit 5s? couldnt keep 4 on the ground ever!!!
    tower&winghobbies? CRAZY torque for brushed. I hear the single or dual 770 ho KD is faster, no where near the torque, and like our friends say, will suck a pair of 5000mAh 8.4 7cell nimh's down in 15 minutes. WHY BOTHER? And as I type this im looking for a dewalt cuz im too poor to buy mamba, can only dream for now and live vicariously thru others on youtube. Just bought some E Revo tires for biketrack/skatepark style driving, any pinion suggestions beside the 18T? We need more brushless Summit videos!!!!!!! MORE SUMMIT VIDEO in general!
    DEWALT SUMMIT & MINI E REVO
