Thread: Titan 775 ?
    Aug 2009
    Hickory,NC
    146
    Titan 775 ?
    What is the rpm range of the 775? Thanks
    Sep 2009
    3,035
    most mubachi motors on 12 volts tend to register around 22,000 rpm, much higher then 25k rpm consistently and they over heat. For comparisons sake a 22000 mamba motor has a max around 50-60k rpm with much less heat issues
    MAN, Use Common Sense
    Funky Gecko, SumVee HDE
    Sep 2009
    3,035
    motor rpm/volt chart
    go down to mabuchi 750
    http://www.slkelectronics.com/ecalc/motors.htm
    Aug 2009
    Hickory,NC
    146
    Thanks for the info.
