    Apr 2010
    Townsville, Australia
    629
    Question shock oil and diff oil weights & other questions related
    can anyone tell me what is the weight of the oil used in the summit's shocks (standard)
    how about the front / rear diff? does it use use oil or grease? whats the weight of the lube to be used there?
    how often should the shocks/diff's be rebuilt
    do you have to use the genuine traxxas lubes?can you use lubes from say losi or associated?
    can you use fully synthetic products like "mobil 1"
    thanks
    Aug 2009
    Spruce Grove, Alberta
    1,552
    Here is a link to the Summit parts list on this site, http://www.traxxas.com/PDF-Library/5607_parts.pdf
    The Shocks use 30 wt
    The rear diff uses 110k wt
    I don't think it matters what manufacturer brand you use although some labeled differently. all these products are made of silicone oil I would avoid things not made specifically for rc cars.
    I recently used team associated 120000wt diff oil. in my rear diff.
    http://traxxas.com/forums/showthread.php?536733
    Sep 2009
    Victoria B.C Canada
    5,200
    I'm using 45wt from team assosiated for the shocks
    Mountains cant stop me
    they have tried
    Aug 2009
    1,552
    Quote Originally Posted by jamann
    I have been meaning to beef up my shocks, with 45 or 50. just to darn lazy
    Apr 2010
    629
    thanks guys for the info. but the other main question was the use of mobil 1 fully synthetic products? can it be used instead of silicon based products?
    Sep 2009
    3,111
    most 1:1 automotive oils have detergents and chemicals used to clean the metal insides of a cars engine, I dontthink they will do well with plastic shocks and rubber o-rings. But motor oil is kept in plastic bottles - hmmmmm - but I would still pony up the cash for the real silicone shock oil. save $2 now pay $20 later.
    MAN, Use Common Sense.
    Outside? THERE IS NO BOX !
    Aug 2009
    1,552
    Quote Originally Posted by stinger30
    How would you even guess what oil to put in where?
    Apr 2010
    629
    Quote Originally Posted by noir522
    ah ha...ok, you have answered my question then, i will forget about mobil 1 and use the silicone stuff instead
