Results 1 to 14 of 14
    Jun 2009
    110
    Setting up novak 5.5hv
    Other then the motor and ESC what will I need to se this combo up?
    I will be getting the CC MMP and the Novak 5.5HV. I know the MMP has bullets already attached. Will I need more bullets, wires (gauge?), CC link kit?
    ALso with the CC link do I need it straight away for setting up a sensored system or can I use it later on?
    321
    the castle link can be bought later on.
    myself: I got the field programcard and comes with usb cable and can be used both ways, with or without computer.
    get some 12awg and the 5.5mm bullets from castle creations itself.
    5.5mm can handle a bit more amps then the stock bullets on the MMP
    oh, and you need some heatshrink
    slash 4x4 VXL, Novak HV4.5, MMP
    Aug 2006
    Amarillo, TX
    9
    Don't forget some 5mm pinions. Your stockers won't work
    Sep 2001
    342
    Castle has been including a coupon for Castle Link with new MMPro's. It entitles you to a free USB link or the new field link fo $10. Most important default settings to change are to remove the timing advance and to defeat reverse if you're racing.
    You may want to relocate your controller to the front mounting location to make room for the larger motor. If so, then you'll require the Rustler VXL receiver box.
    I approve of this message
    321
    it does fit
    Sep 2001
    342
    Yeah, I had mine mounted that way, but moved it to better accomodate the sensor wire.
    321
    hey mark. do you run the HV4.5? what gearing?
    Sep 2001
    342
    HV4.5 MMPro - 12/54 (indoor clay track)
    Apr 2002
    glenwood iowa
    165
    hey dumb quest where did you get the pinions for the novak, i have a 4.5 and had a 5mm 14t laying around but the teeth on the pinion r bigger and wont mesh.
    its only money
    RC Turnbuckle Jr. asheck's Avatar
    Nov 2007
    Kansas City
    7,361
    Novak sells them, as well as alot of other places. You must have a Mod 1 pinion. What you need is a 32p, or a mod .8
    _
    _
    _ 3 lines are all that's allowed in a sig.
    Apr 2002
    glenwood iowa
    165
    k will eighter a mod1 or a 32p work???? thank you
    its only money
    321
    mod1 wil not work, mod0.8 is the one you want
    Jan 2010
    louisiana
    258
    How hot does the HV4.5 get?
    Revo 3.3, Slash 4x4, Savage X it really does suck.
    Irvine, CA
    401
    I have only had my 4.5 up to 138.
    4x4 PE & Beyond...
