Results 1 to 20 of 20
    Jan 2001
    Ultimate RC, CA, USA
    1,128
    Video: Cleaning rubber-sealed bearings, completely
    For folks who run in water or who just like keeping your vehicle running as smoothly as possible, I've put together a video showing how quick & easy it is to do a truly thorough job of cleaning out your Traxxas rubber-sealed ball bearings:
    The #1 Traxxas RC fan, 12 years & counting!
    Jan 2010
    Green Bay, WI
    2,269
    Great! Looks good.
    Don't remember if it said on the video but how often do you recommend doing this?
    PLEASE do not PM me and immediately go offline :p
    Jan 2001
    1,128
    Thanks. There's no way to answer that question though, as it varies so dramatically. If you run through salty or mineral-rich water, I recommend doing it immediately after you're done running for the day; no more than a couple hours later, for sure. If you race on a well-groomed, damp clay indoor track, it only needs it every couple months, though you might choose to do it once a month for that extra 1/10000th second per lap. Normal street and dirt bashing? Something in between.
    Jan 2010
    393
    Very good, Thanks you
    Elgin,IL
    156
    Thanks; that is extremely helpful.
    Can 3 and 1 oil be used to lubricate the bearings ?
    Jan 2010
    SE Wisconsin
    123
    Thanks Jang. I was just logging on, to look for a how to on this and BAM there is your post. Awesome.
    Jan 2001
    1,128
    Thanks all, glad this helps!
    rcfan60123: Yep 3-in-1 will do just fine.
    Apr 2010
    180
    Good info thanks!
    Can I use the tamiya molybdenum grease? I've read in other forums that grease can stay in the bearing for longer and has better handling of high temps??
    Thanks in advance
    Jan 2001
    1,128
    If you use very, very, very little of it, yes, it's great stuff, though the heat tolerance aspect isn't an issue in our trucks. You should put so little on, though, that after working it in, it shouldn't be at all visible.
    If you run through water or mud, though, there's no point in using a grease as it just takes much longer to properly apply and is harder to get out. A completely different option for wet running is of course to pack your bearings solid with grease, but this increases friction and also makes them much more difficult to clean.
    Apr 2010
    180
    Thanks for the info might get some 3 in 1 now as it's quick and easy to apply
    Jan 2001
    1,128
    I've never used PB Blaster myself, but from what I'm reading, it sounds very much like WD-40, the "lubricant" in which has much more stiction than you want to leave in small ball bearings.
    Jun 2005
    Yakima WA
    859
    I'm about ready to pack the bearing that supports the slipper assembly full of grease. It's the only one that I have issues with. The others seem to do fine with normal cleanings and oiling.
    Every single time I hose my truck off from a couple battery packs worth of dusty track runs, that bearing freezes up within a few hours. I drilled a hole through the chassis in front of that bearing to help drain off the water that likes to dam up against the bearing there and even use an air compressor to dry the truck off. No matter what I do, I end up having to pull the back of the truck apart to get at that bearing and clean/lube it. And it's not like I sit there with a pressure washer nozzle against the bearing.
    I think one bearing full of grease will be fine. Or maybe I'll just replace that one with a stainless unit.
    Turbo in the front, groceries in the back.
    Jan 2001
    1,128
    Quote Originally Posted by turbowop
    As troublesome as that particular one is, I think that's a good idea!
    Apr 2010
    180
    Ive taken apart all the bearings numerous times and the slipper one is the one that is almost always packed with dirt/crud..!
    Jan 2010
    249
    Bumping this for the noobies
    Jan 2010
    249
    Move along nothing to see here
    4x4 Slash, Jan 2010
    2x4 Slash, X2 May 2010
    Jan 2006
    Saco, Maine
    402
    I saw this post a little while ago and it made me think of cleaning my bearings in my Rustler, 2WD Slash and my 1/8 buggy. I'm finally ready to try cleaning my bearings, I have some bearing oil to re lube the bearings after cleaning but now I'm just wondering what I can use other than motor cleaner from my LHS. I was thinking maybe carb & choke cleaner or maybe brake cleaner from a auto parts store. Would either of these work without doing any damage to the bearings?
    Rustler VXL|Blitz|OFNA Picco
    Jan 2001
    1,128
    Carb cleaner often leaves a lubricating residue behind so I wouldn't recommend that. Brake cleaner should do the trick.
    Jan 2006
    Saco, Maine
    402
    Ok thanks for the reply. Ill try it and see how it works.
    Jan 2010
    119
    I do that for my bearings before I even use them; they come packed with thick grease that produces a lot of drag. I recently tried this DuPont silicone/teflon spray lube from Lowe's that seems to be work pretty well. Soaking your bearings in a solvent in an old prescription pill bottle is a good way to save on motor spray, especially if they are really grimy. I love the RPM Bearing Blaster, much more efficient.
    PLEASE wear rubber gloves if you're going to just hold a bearing while you spray it. Keep that spray off your skin.
