    Apr 2010
    180
    Basic heatsink part #?
    Hi all,
    I have a slash on it's way to me and I've been stocking up on parts e.t.c
    What's a basic heatsink I can clip onto the standard motor??
    Thanks in advance
    Feb 2004
    California
    589
    That's for a Traxxas Boat. I believe this might be the one you need. Traxxas 1522 Motor Heat Sink. I think I've seen it in Blue as well. I orderd one the other day, so I'll let you know how it works.
    FangsCPO
    "How fast was I going Officer?" Wow?
    Baton Rouge, LA
    1,066
    Are TRA3822 and TRA1522 the same deminsions, only different colors?
    / 16
    Feb 2004
    California
    589
    I really can't say but I know I read somewhere that TRA3822 was for a boat motor. Everyone else is using the TRA522 but they are having to do a Mod since it's too long and the wire get in the way.
    FangsCPO
    Apr 2010
    180
    Quote Originally Posted by dtnel
    TRX told me all I need is the esc fan and that's its. have a pocket temp gun and don't let the exterior of the motor get over 200. the main issues people are having is grass not geared properly and 3S batteries but if you run stock spur gear use a 12tooth or less pinion on the motor and you should be good.
    Cool, sounds like good info - I've got a duratrax temp meter so I'll be checking it out. I'll be using the outerwears chassis cover as well so hopefuly should be ok..
