Results 1 to 14 of 14
Thread: bearing lube
    Dec 2009
    26
    bearing lube
    Just wondering what kind of lube you guys recommend for bearings. I have the stock wheel bearings that came in the 1/10th 2wd slash. Also would I use the same for the vxl motor bearings? Is there specific I should use or something I can easily pick up locally?
    Jan 2010
    393
    the stock wheel bearings are seal so they don't need lube, I hit them with a shot of WD40 for good measure after I go though water. the VXL motor I have no clue,
    Jamul, CA
    484
    For bearings, I use automotive heavy duty bearing grease
    SLASH IS FIXED!!!!!!!!!!!!
    Jan 2010
    Fairfield, ca
    783
    Auto grease on exposed bearings? You don't collect everything on them? Or do you just open and pack? I use wd40 to clean bearings, hit with simple green, once clean 3in1 oil is great.
    Sorry simple green, wd40, then clean with cloth and hit 3in1
    For your motor? Disassemble, motor spray bearings and lube with really light oil, again, 3in1.
    Traxxas should just cash my checks for me
    Jan 2009
    Sheboygan, WI
    2,345
    Quote Originally Posted by SirJaymz
    The bearings are sealed only to the point of keeping out MOST of the dirt they are subjected to. They are not sealed from moisture or sand though. WD40 is more of a moisture repellent than a lubricant, so I suggest sticking with bearing oil. 3in1 oil will work in a pinch, but is too thick to properly penetrate the seal on the bearing.
    Jan 2010
    393
    Quote Originally Posted by DeanSky
    good to know, I'm sorry for posting wrong info
    Springfield, MO
    3,681
    bearing lube? Run them suckers till they freeze and replace!
    Jan 2010
    Alabama
    859
    Care to suggest what oil folks should use? Ideally?
    Chris
    Summit 4s
    DiggerPede 2s & 3s
    Slash 2WD 2s
    Jan 2009
    Sheboygan, WI
    2,345
    Quote Originally Posted by Krispy
    Any kind of bearing lube will work. Some hardware stores carry it, but I picked up some Trinity bearing lube while I was at the hobby shop. Works nice and has a real fine needle tip applicator.
    111
    i use bicycle bearing lube... actually i use nearly all bicycle lubes etc on my slash
    Dec 2008
    Gettin' Lucky In KY
    3,882
    I'll take the seals out of the bearings very carefully with a sewing needle. Then I'll put them in my RPM bearing blaster and flush them with Brake Cleaner. I'll take a small screw driver and apply just regular Valvoline wheel bearing grease in them, then I'll re install the seals.
    For motor screws I'll use an oil based lube such as Trinity Royal Oil, or 30wt silicon shock oil.
    Jan 2009
    Sheboygan, WI
    2,345
    Quote Originally Posted by CarGuy7a
    You lube your motor screws? I guess Im confused.
    Dec 2008
    Gettin' Lucky In KY
    3,882
    AAAHHH!!! meant to say "motor bearings".
    Jan 2009
    Sheboygan, WI
    2,345
    Thats what I thought but wasn't sure.
