+ Reply to Thread
    May 2009
    235
    Fuel coming up through the glow plug
    There fuel coming up through the glow plug, and also some exaust, but the glow plug is nice and snug, Is the cooling head threads striped or is it just the tunning
    RC Turnbuckle Jr. KyLeader7's Avatar
    Jul 2007
    5,002
    First identify where the fuel is coming up from. If they were stripped, your glow plug wouldn't be 'snug'.
    Learn by doing
    May 2009
    235
    the fuel is coming up around the glow plug you can here it bubble and see it, or what about the washer, if it was not the right way would that do it
    Apr 2009
    Detroit
    839
    Too rich I use to have that same problem when I was first starting out with nitro. Make your to check your idle screw gap. The carb should 1-2mm from close.
    Stock Settings
    HSN 4 Turns from close
    LSN Flush with ring
    Speed is the rate of change of distance with time.
    May 2009
    235
    sweet thanks guys, my idle screw was way to rich.
