Hi, I almost gone crazy looking for a good on-road wheel+tyre combo (stock talon wheels wear out too soon on asphalt) but haven't found one yet
Something like traxxas anaconda would work?
merv+lipo3s2p1500mAh20/30C=fun
The rear Anacondas from the bandit would work on some buggy wheels. Pro Line road rages would work also or road rages on titus bead locks... It all depends on what you are looking for. You could do buggy wheels all the way around or a truck wheels...
fine line between hobby and mental illness
Thanks for the quick reply!
Do you know what hex the anaconda rear wheels have? If they have 12mm hex they could be perfect
I'm not looking for anything special, just a good combo to run on pavement![]()
PS: there are no LHS near my town so I have to use forums and google to find what I need, but I can say that there's some serious lack of infos about wheels and tyres![]()
somebody had a topic about his - he said they ballooned quite a bit.Originally Posted by psimem
... oh, and sorry about your wallet
I was probably going to get a set of the Proline SpeedHawg's (or streethawgs, or whatever they are called) to mount on my Titus Beadlocks for high-speed runs.
Anacondas are direct fit for Merv (as all the other Rustler wheels). They have 12mm hex. But I wasn't impressed much with Anacondas' performance on Merv (bad grip). But maybe it will improve when temperature will raise, as they need to be hot to get grip (and it's around 0 degrees celsius here).
I really liked the HPI super nitro foam to do some onroad with the mini
Thats what we used for top speed runs
World fastest E-revo 91.2mph / Revo 75mph
ABmods
what kind of wheels are those? I like the fact that the rears are wider then the front
Good to knowOriginally Posted by biermann
Do you confirm that they balloon (or not)?
Unfortunately around here it's almost impossible to find beadlocksOriginally Posted by BAC5.2
Nice!Originally Posted by Over_revO
What's the outer diameter?
I LOVE the HPI Vintage Performance tires with the vintage wheels. Runs well, great grip and controlability and shallow tread hard compound works well on streets.![]()
Could you please post some measurements? hex size, outer diameter, width?Originally Posted by SF1688
Thanks
My friend have them for the moment so i cant measure exactly..., but they are slightly smaller than the original talons, may be 1/8 of inch smaller maximum.Originally Posted by psimem
I got them on ebay, they are discontinued but theres some set left that show up on ebay sometimes...
ABmods
STILL CANT FIND A SET WAITING FOR U TO SELL URS LOLL I FOUND A SET BUT THEY WHERE YELLOW N IM 90% SUR ETEHY ARENT DYABLEOriginally Posted by Over_revO
My Spelling Is Bad
My Moma Says Im Special
Hi, it's a direct fit onto stock VXL Slash...almost exactly the same dimension as the stock ones...Originally Posted by psimem
Thanks to everyone!
I'm planning to do some sort of list of all these wheels so if anyone else wanna post...![]()
I see, so they are smaller than revo'sOriginally Posted by SF1688
I just ordered the anaconda 2.2" (rear version) and as soon as they arrive I'll post some pictures![]()
crfrider please post a link where I can order those wheels.
My lhs had 1 set and the rims were ugly.. I'd need 2 sets anyway.. They were white so I guess I could paint them red to match the car but yours look way nicer
Mediafire?! No list, just add about e cigarette. Only way to get my nicotine fix out of those is to crush it roll it up and smoke it
Traxxas should just cash my checks for me
just had Rick from Gone Bananas make me some foams, havent done many speeds runs yet but i will tell you that the shiping was super fast and the craftsmanship was unparrelelled. I will report back with after-run results
WARNING LEVEL: 60% and rising!
Why can't you just install those Tracer wheels without using the hexes? That slot looks like it'll slide right over the hex-pin. Just put the wheel on, then cinch it down?
Already tried and:Originally Posted by BAC5.2
1- the axle isn't long enough
2- the pins are too small
3- the center part of the wheel rubs against the axle-carrier
Now I'm planning to do some mods...
foams from gone bananas
Can't see 'em.
After some mods (pictures coming soon) today I finally tested the anacondas: on wet asphalt they quite impressed me, good grip and balance![]()
