Results 1 to 4 of 4
Thread: Tires
    Feb 2010
    313
    Tires
    What happens if you put front 2wd tires on the front of the 4x4 (offset is diff). Thanks
    50 characters? Fail.
    Apr 2009
    Wisconsin
    358
    They will be a little wider.
    Slash 4x4 RTR
    Platinum Slash 4x4
    Jan 2010
    Southern Oceania: AU MY SG
    272
    difference is only about 3mm
    if you have to use a full set of 2WD wheels on your 4x4 i'd put the 'front' ones at the back
    extra width on front might cause body rub
    Feb 2010
    313
    Ok, so put the fronts in the back....... I had just assumed from what I had heard that it would be terrible to but the 2wd fronts on. Its all I have at the moment.
