Results 1 to 3 of 3
    Surprise, Az
    44
    reciever question
    I have a 4 channel am reciever and am trying to figure out where the servo's goe. The first port says b, I assume battery. Is this where the esc plugs into? Is the port labeled one for the steering servo?
    Also does anyone know on a non traxxas motor which poles are positive and negative? I dont see a plus and minus and the wires comming off are yellow and green.
    RC Qualifier PeterV's Avatar
    Jul 2008
    508
    B = Battery
    1 = Steering
    2 = Speed control
    You must have a Tamiya motor. The yellow wire is positive, but some Tamiya kits call for the motor to be hooked up "backwards." If the motor isn't spinning in the proper direction for your application, just reverse the motor wires (attach green to black instead of red).
    Surprise, Az
    44
    Quote Originally Posted by PeterV
    B = Battery
    1 = Steering
    2 = Speed control
    You are correct on the motor, thanks.
