Has anyone tried using front rockers on the rear.
Sure did.
I made a post about it a while back.
So how did it work out for you...tried to find your post, but didn't see it right away. Been thinking about trying this out to keep the rear from sagging too much.
Originally Posted by BAC5.2
Could you link to the post please?
thanks.
If not, do they throw the pushrods into the back of the a-arm? And do the shafts rub the middle of the top a-arm at full extension?
thanks.
No rubbing at all. The back sits pretty high, but it squats a lot less when accelerating, which is nice.
can i use all 4 front HR rockers, or is better 2fr. and 2 rear?Originally Posted by BAC5.2
Depends on what you want. I was tired of bottoming out the rear suspension when accelerating, so I put front rockers on the rear. The front end lifts quite a bit less now.
If you want 4 front HR rockers, I have some you can buy. They don't have bearings, but your stock bushings work just fine in them. I'll let them go cheap, just PM me.
