    Jun 2008
    Guelph Ontario, Canada
    342
    Small gravel in driveshaft
    Is there any way to stop this? Or is it better to run with the plastic driveshaft cover off?
    P4d4 & Sl4sh
    Jun 2005
    Yakima WA
    859
    Turbo in the front, groceries in the back.
    what size of shrink tubing did you use? i thought of doing this over the weekend but couldn't decide what size tubing to get.
    Jun 2008
    Australia W.A Karratha
    2,374
    i think the shrink tubing would grab rocks that are thrown at it since its rubber and try to pull them in which may bend the drive shaft. so i did this.
    rtr slash 4x4
    2s lipo
    some other rc stuff
    Oct 2006
    Texas
    172
    Quote Originally Posted by bandit
    Last time i checked rubber makes things bounce not stick.
    Jun 2008
    2,374
    not as in sticky but it has more friction than the smooth aluminium so rocks would be forced to spin with the shaft a little more and may go up under the cover.
    rtr slash 4x4
    2s lipo
    some other rc stuff
    176
    i think the best gravel/dirt mod for drive shaft is a piece of lexan shoogoo to your frame where the d.shaft enters the chassis.then u take your body reamer and ream a hole.no more scratched driveshaft.
    Dec 2006
    Los Angeles, CA
    188
    Hi, you need to definetly seal the front of the drivehaft and plug the drain holes. But I think the place where most of the dirt gets in is the big hole next to the motor, see the pictures below. Easy to fix, make a small foan plug and stick it in there.
