Hello Guys,
Well, I got my Slash 4x4 last week and I wanted to have at least 1 more channel on my radio system to turn on/off the lights remotely... If you remember, I was the first to find out how to convert the old TQ 2.4Ghz transmitter from 2 to 4 channels when I got my ERBE last year... If you don't remember it, check my thread about it: http://monster.traxxas.com/showthread.php?t=465950
So, after a few emails and PMs about this, I was wondering if it was possible to convert the new TQ Link 2.4GHz transmitter from 2 channels to 4 channels (we already have a 5-channel receiver on the truck)... And, the answer is again, YES!!!
I must admit this mod was very easy to do because the new TQ 2.4Ghz Link is fully digital (no trims or switches)... On the old TQ 2.4Ghz transmitter, I had to add and remove a few parts on the board, and I spent some time trying to figure it out...
As I always say, this mod is working just fine for me, but, this will void your warranty and I'm not responsable if you ruin your transmitter...
I suppose you know how to open the new TQ Link 2.4Ghz transmitter: 5 screws on the back, remove the plastic cover from the on/off switch, remove the battery holder and the 2 screws on the board...
After that, you can see 4 empty pads on the board that says: UP DWN (RSW) and UP DWN (ISW)... You have to connect 2 switches to those 4 pads... I used a three positions switch, that is: OFF-ON-OFF (for the Summit's T-Lock)... But, you can also use a two positions switch, that is: ON-OFF (for the Revo 3.3 reverse)...
I labeled the pads and also the switches so it's easier to follow... As you can see, pads 1 to 4 goes to the exterior legs on the switches (yellow and green wires)...
Also, you need to connect the middle leg on both switches (white and purple wires) to ground... I used an empty ground pad on the top board where the trims are...
This is how my temporary setup looks on my new TQ 2.4Ghz Link...
And, a video to prove that it works...
Hope you like this new mod... Now, I can use it on my Summit!!!
Daniel.
PS: I'll try to find out if it's possible to make the 5th channel work...
I like to do these things...
[/IMG]
