Results 1 to 7 of 7
    Jun 2008
    Guelph Ontario, Canada
    342
    New 4x4 Slash Owner
    Hey all,
    Just got a 4x4 slash and haven't driven it yet. Is there anything I should do to prep. I am not new to the hobby, I own a Stampede now and have owned a 4x2 slash and a rustler.
    What parts should I stock up on?
    Thx
    P4d4 & Sl4sh
    St. Pete FLA
    543
    Check gear mesh and slipper setting (mine was locked out of the box). Make sure to check all nuts and bolts for tightness. Locktight metal to metal screw contact. Check the servo arm travel to make sure it doesn't contact the center drive shaft (mine did and gouged the shaft). Stock up on normal parts. In particular, arms and rear axle shafts. Run the snot out of it for 5 or 10 minutes, then check it again and see if anything worked loose.
    houston
    997
    get the front thing that the drive shaft connects to and more axles those are the main parts i have seen that have been breaking
    RC Turnbuckle Jr. RC-Crazy's Avatar
    Apr 2008
    Bellevue, WA.
    3,850
    double ck & tighten ALL the screws. thread locker ALL the metal to metal contact screws.
    Slash PE & Ja-two.
    Jun 2008
    342
    Quote Originally Posted by RC-Crazy
    Without completely disassembling it, where are the metal to metal parts?
    P4d4 & Sl4sh
    Jan 2003
    Fairbanks, Alaska
    393
    Check exploded views in the manual.
    Oct 2008
    Iowa
    381
    Most of the metal to metal parts are in the front c hubs and rear bearing carriers
    Been there, broken that.
