    Dec 2009
    Germany
    205
    Traxxas 2,4 Ghz VS XXX 2,4Ghz
    Hi guys,
    I´ve read in some threats that a lot of drivers change their Traxxas radio
    to another like Futaba 2PM or Spectrum or whatelse...
    What´s the reason therefore, and what´s the advantage of the other radios?
    Thanks for your infos
    Mar 2005
    Shawnee, KS
    149
    The AM rtr radios for sure get changed out alot.
    Run it like you borrowed it!
    Dec 2009
    Germany
    205
    aha
    Traxxas 2,4 Ghz VS XXX 2,4Ghz - that´s the heasdline
    Jun 2009
    ZA
    106
    The older model 2.4GHz from Traxxas did not have EPA and other features/adjustments. It just had steering and throttle trim. The newer model does have the additional features though.
    http://en.wikipedia.org/wiki/Dig_Dug
    May 2007
    719
    I am using the Traxxas 2.4GHz for some of my smaller RCs and my Summit (4 channels) however I would definitely go Spektrum or Futaba for the rest, the Traxxas setup is a real headache for changing settings and things since the competition all have an LCDs and visible menuing.
    Oct 2005
    South Florida
    18,588
    You can store multiple RC's in the memory with Spektrum or Futaba, end point adjustments, you can even change the response speed of the servos, some have an abs type feature where you can hit a channel and it changes how the brakes react according to how you set them, lastly some even have telemetry to tell you things like receiver battery level, speed, and engine temperature.
    Basically the Traxxas 2.4ghz is a great start in the digital controller world, but when you get past that point and you want more then the aftermarket radios just have more features and probably faster response.
    Founder of H.U.A.
    Hop Ups Anonymous
    Dec 2009
    Germany
    205
    Thanks for the infos, now I can see the difference..
