Page 14 of 14 FirstFirst ... 4121314
Results 521 to 537 of 537
  1. #521
    Apr 2013
    Australia
    333
    Can someone explain if Steve's explanation of using oil in the rear diff instead of grease is in the housing or the diff centre itself????
    Keep on Bashing and you will keep on Trashing
  2. #522
    MS
    90
    The diff center, the plastic cup that is screwed to the ring gear. The diff housing is not sealed and will not hold fluid.
  3. #523
    Apr 2013
    Australia
    333
    Thanks turnleft, I'm going to work on diff tuning this weekend, with my lack of ability at the trigger I find I get to much wheel spin at the rears in loose conditions, centre diff is in.
  4. #524
    MS
    90
    I have 10000 in my rear diff and it works great for loose conditions.
  5. #525
    friendswood texas
    1,262
    Quote Originally Posted by Scubbastevebmxr View Post
    What setup tools do you use Steve (or others)? I've been looking at hudy's off road setup kit and integy's setup kit. Any suggestions on total offroad setup systems?
    Just a basher here but I run steve's set up. I use toe and camber guage from RPM and they work great.
  6. #526
    Jul 2005
    elkton,maryland
    23
    why do you use thick weight shock oil in the front and rear shocks 55wt and 60wt seems very thick for offroad racing please help max
  7. #527
    Apr 2013
    Australia
    333
    Quote Originally Posted by maxxpower78 View Post
    To help absorb impact on the up ramp of a jump and to also help absorb landing, as you try to land front axle first on the down ramp of a jump. Softer in the rear to allow the rear end to squat under power to give more traction to the rear wheels.
  8. #528
    Jul 2013
    4
    Hi,
    Can anyone help me get a setup for my race slash 4x4.
    Its running the STRC LCG chassis and the proline protrac kit. My track is a fairly bumpy outdoors track favoring the 8 scale nitro buggies. I have Texin RX8/Pro4 4600 and Savox 1258tg servo. I have the 13mm GTR shocks whith AE springs. Its really fast but tries to swap ends all too easily even whilst powering on the straight. It jumps great though but just not stable.
    My current setup is pretty much Sleydan's as far as oils and arm mounting points go, but running 3deg toe in and 2deg neg camber at rear. Shocks mounted middle on tower and full outer at rear. At front I got 1 deg toe in and 1 deg neg camber and got my shocks middle on tower and 2nd from outside on arms. I am running Sleydan's sway bars.
    My other truck is a race prepped TLR Ten SCTE 2.0 and that thing is just way faster and more stable everywhere, but it jumps real bad.
    Please help!!
  9. #529
    RC Turnbuckle Jr. mwe-maxxowner's Avatar
    Feb 2004
    pageland, sc(south of monroe)
    3,755
    I have the gtr shocks on my truck. What springs should I look into running on these?
    460, straightpipes, buried throttle, nuff said :D
  10. #530
    Oct 2013
    Maryland, USA
    160
    Hi Guys,
    I have slash 4x4 and I am confused about this it has front differential oil, rear differential oil and center differential oil where did you put center differential oil? Any ideas....
    Front end:
    - outer steering link: front hole (plastic knuckles)
    - shock springs: Slash 2wd fronts or Rustler fronts work well
    - camber link: outer/ lower & inner/ upper
    - diff: 10K to 15K
    Rear end:
    - sway bar: black
    - diff: 5K to 7K
    - install center diff (50K to 100K)
  11. #531
    Feb 2004
    3,755
    Do you have a center diff for your truck? Or only a slipper? The center diff has a diff case you can open up just like the front and rear diffs that you can put oil in.
  12. #532
    Dec 2013
    15
    Hi Guys,
    we have a race and bashing track in a local wood. Do have any recommendations what is the best setuo for my Conditions ? The wood soil is anywhere between hardpacked and loose (more loose than hardpacked) but not loamy and most of the time dry. The most important thing for me is acceleration and tracking stability, everthing else does not matter.
    Thanks for your help
  13. #533
    Mar 2014
    Oak Ridge, TN
    84
    I have read this entire thread and onlt one unanswered mention of GTR shocks from the current slash ultimate .
    Is there a listing of all traxxas shocks, springs and their compatability, and sizes ?
    Their shock names are confusing.
    Slash Ultimate 4x4
    STAY AWAY FROM BIZARRE HOBBIES
  14. #534
    Jul 2014
    Selb, Germany
    15
    Hi,
    what is a good setup for the street? I also drive a litte bit on gravel but mainly on street.
    Thanks
  15. #535
    Jul 2014
    Selb, Germany
    15
    Quote Originally Posted by aggie rustler View Post
    via RCShortcourse.com from sgrid - thanks mp3ranger
    Front end:
    - diff: 10K to 15K
    Rear end:
    - sway bar: black
    - diff: 5K to 7K
    Which unit do you mean? CPS/CST or WT?
  16. #536
    Aug 2014
    Poland
    4
    The diff oils is always in cps.
  17. #537
    Aug 2014
    My brain is spinning. Is there anywhere I can find a glossary and some good fundamentals? Thanks
