Results 1 to 4 of 4
Thread: How many fans
    29
    How many fans
    I'm running a stock set up.with a 3s 5000mah. How many fans for the motor should I run.
    Youngsville, LA
    69
    I ran 1 on the motor and 1 on the esc
    Oct 2010
    Parsippany, NJ
    646
    none as long as you're not geared too high. if you get too hot you need to gear down or take breaks between packs
    Easton, MD
    278
    Stock motor on 3s can always use a fan!
    I use a 12v computer fan glued to an "Intecrap" heatsink and plugged directly into the battery using a power tap.
    This works well on 3s as it is 11v - 12v or so.
    It also does not draw from the ESCs internal BEC.
