hey again...
so as i stated in my maximizer thread i have some of them "egging" meaning wobbling from L to R when under throttle...
when inspecting 10min ago i saw that the tires on all 4 wheels are ripped...
will post a pic of it soon...
im really really unhappy (mildly said-warning level too high) about that
after bagging the stock tires-also due to 17mm adapters- but mainly because my stocks ripped apart with stock NON-BL setup and 4s lipos!!!
they ripped apart right outside the rim, before the tires goes "vertical" if you can say so...just right outside the rims...all of them......
i bought mashers and roadrages with maximizers / crimefighters and badlands with rulux´s, both 1/2 offset
i gave the mashers about 5 batt changes and now im at the same point....
1 of my tires is egging really hard, 2 a bit, 1 seems ok...
BUT ALL OF THEM ARE RIPPED AS THE STOCK ONES
what the heeeck...
am i doing sth wrong?are there better tires than rpm?
i dunno - i thought i made a good choice but seeing this makes me really sad... is there any way to prevent this?
also by the amount of users here i thought this would have happened before, but i didnt see any posts on that issue before..
even more as many of you go 6s constantly and i went 4s, 1 time 5s...
gearing 56/18, mmm 2200kv...
help pls!!!
