Results 1 to 12 of 12
    Jan 2008
    52
    so i sending back my vxl
    so i tried to run my slash with my thunder power 3300 25c 3cell and soon as i pulled the trigger it went about 10ft and lvc kicked in[ have same problem with rusty] so i used the pack in my 2+4 slash which has a mm5700 setup and ran for at least10+ min no problems. im just upset i have to send it back, i guess im just venting but to all that have this problem will understand
    Edited for Language
    -ksb51rl
    Sep 2004
    Woodhaven, MI
    2,069
    curious what your MM 5700 is geared in the 2wd Slash, and what temps?
    Welcome to Traxxas.com Yes, EVERYONE here IS a Pro Racer.... [/sarcasm]
    Feb 2009
    Sacramento
    1,861
    buy a lvc or alarm
    Dec 2009
    Boise, Idaho
    55
    Is the LVC a universal problem with all Slash's or some percentage of bad apples?
    Nathan
    Jan 2010
    Seattle
    653
    the one time i had lvc problems i lost $300 in batteries...
    Paul
    Slash 4x4
    RC Racer liv4rc's Avatar
    Sep 2003
    107
    [so i tried to run my slash with my thunder power 3300 25c 3cell and soon as i pulled the trigger it went about 10ft and lvc kicked in[ have same problem with rusty] so i used the pack in my 2+4 slash which has a mm5700 setup and ran for at least10+ min no problems. im just upset i have to send it back, i guess im just venting but to all that have this problem will understand
    Please remember this may not be an ESC issue, Your battery is only capable of 82.5 continous amps. The VXL system requires a minimum of 80amp continous so even in ideal condition your battery is only is able to meet the minimum. If your battery is not balanced, fully charged or if the pack has seen high use it will not be able to power the ESC correctly.
    Feb 2003
    97
    Quote Originally Posted by liv4rc
    I don't believe this is correct although I would borrow a 2nd pack to test anyways. I have a VXL speedo in another BL setup and it tends to be finicky sometimes as well. Have to turn it on/off a couple times to get it to work but finally does. The 80A rating of VXL is max it can handle before overheating, the motor determines the current needed from battery. And I don't believe a stock slash 4x4 setup would need anywhere near 80A continous current.
    Sep 2003
    107
    The 80amps is the minimum a battery must be able to supply in order to keep from tripping the LVC. Traxxas has always stated the VXL system requires lipo batteries that are capable of delivering 80A continous in order to operate properly. Not sure where you got the 80amp /overheating info.The VXL is capable of 320A Peak and 200A continious. You may want to call Cust. Service and they will clear up any confusion.
    Jan 2008
    52
    then how come i can run the pack in my mm setup with no problem? imean i took the pack from my vxl setup and then i put it in the castle set up with no problem
    Sep 2003
    107
    Hard to answer not knowing the specs of the Mamba system you are using(what is the minimum amps needed etc..). I am not discounting the fact there maybe an ESC issue, I am simply stating batteries are an important part of the complete sytem that get forgotten about often.
    Jul 2008
    Chino, CA
    378
    I had a VXL that lost its LVC. It would run for a few minutes and they cut off. It ran fine in NIMH mode though so I just ran it that way until it died. when I noticed that the speed dropped, it was time to stop before killing my lipo.
    I read of plenty other people having the same issue. Its a good ESC to bash but that's about it. That's why I sold the one out of mt 4x4 for a MM.
    Aug 2006
    Renton, WA
    1,968
    You seem pretty confident of the 80A requirement, but I've never heard of that either. I just checked
    http://www.traxxas.com/products/acce...NST_070706.pdf
    Do you have a ref to share pls ?
    The LVC checks voltage, so if the demand from the motor hasn't tripped that low voltage on the pack, where would the 80A requirement come from ? I think the peak for the vxl motor is 100amps.
    hmmm, I've never seen it spelled that way.
