    Jun 2009
    Nebraska
    382
    New 1/10 scale Slash Brushless?
    All, I have the new Slash that just came out;-) I would like to use the LiPo's I already have but wanted to make sure I do not damage the truck so hear is my ? I have four 3s 20c 1550 LiPo's.
    Can I stack two of them and use my Traxxas parrallel cable to run it as a 3s 3100 (total of 2 lipo's)? Will I have some issue with this type of set up not delivering enough power to the ESC/Motor and thus causing damage because of low "C" output or something else? like what we have seen with the ERBE Thanks in advance for the help.
    Craig
    BL Revo, eRevo, MERV x 3 and still counting.
    Sep 2009
    Upstate NY
    405
    Quote Originally Posted by cdassner
    Craig
    You can absolutely run 3s in the new slash... I have been running 3s in my Artattack (same VXL setup) and did a test run in my 4x4 Slash... its fun but was actually WAY too much power for what I needed on the clay oval... may be fun on an outside MX track though...
    I am by far no expert on Lipos since I barely use the three I own.. but I dont see any reason a 3s2p setup should have any issues in there... its really no difference then having the same as a larger 3s battery... which would work... but like I said... I am by FAR no expert when it comes to C-ratings
    The Bashing Grounds
    Ross M.
    5-Pointer!
    Sep 2009
    90
    That should work.... Call Traxxas and ask them what is the mininum AMPage...
    You must have the ********* lipos for the mini revo?
    3100 x 20c --> 62 AMPS
