Thread: after running
    Sep 2009
    114
    after running
    hi what do i do after i run in the snow with my mini revo. i know to use wd40 but where thanks
    Nov 2009
    117
    All exposed steel parts will tend to rust if the moisture isn't displaced by the WD-40, so almost everywhere especially on suspension and drivetrain components. A-arm hinge pins, pivot balls, steel hollow balls, shocks, screw-heads, steering linkage, servo-saver, slipper-clutch spring & nut etc.
    I think the stock motor pinion and spur gear are plastic, so you can leave those alone.
    Dec 2009
    Idaho
    319
    i never use wd-40. after im done bashing i immediately throw my merv in the sink and wash it off. once it's clean i usually air dry it with my air compressor. i hate using wd-40 tho dirt always sticks to it.
    Piercings can and will get caught in antenna tubes
