Results 1 to 21 of 21
    Dec 2009
    30
    HELP!! Just broke right suspension Arm
    Does anyone know if the 2WD truck has the same suspension arm or if they are different. Any help would be appreciated.
    Nov 2007
    dirty' jersey
    892
    look up the part number and reference it with the 2wd arm. if its the same part number then its the same arm
    Feb 2007
    61
    I am not sure if the 2x4 will fit length wise but the 4x4 arms are molded different so probaly not the same part number.
    Slash 4x4 RTR, CD, sway bars.
    Dec 2009
    30
    I know for sure its not the same part number but I was just wondering if someone had both and could compare to see if it might work for the meantime. It's going to be a couple weeks before we see the stock parts I think.
    Nov 2009
    28
    i beleive they are the same as the stampede and rustler. not sure what the x in the part number for the 4x4 slash means
    Dec 2009
    30
    So if I search for the same part number but just without the X then that would get me to the rustler or stampedes A arm that you think might work?
    Dec 2009
    Mableton, G A, Hey Hey!
    95
    Quote Originally Posted by slash4x4er
    I broke a front a-arm a couple of days ago and my research led me to the rear a-arms on the Stampede/Rustler. I took measurements of my broken 3655x and compared them to information I found on the 3655. Dimensions were identical. I ordered a set of RPM equivalents but they won't be here until next week. I feel it was too easy to break and I don't want to put a stock one back on there unless I have to.
    If no one beats me to it, I will post my results when they arrive.
    RC Turnbuckle Jr. asheck's Avatar
    Nov 2007
    Kansas City
    7,361
    As far as I have seen, the difference is the shock mounting positions. The 4x4 has additional spots for shock adjustment.
    _
    _
    _ 3 lines are all that's allowed in a sig.
    Dec 2009
    95
    Quote Originally Posted by asheck
    If that is the only difference between the 3655 and 3655x I will be happy.
    My bashing style doesn't require many different shock positions. Stiff is the word.
    Registered User majestic's Avatar
    Mar 2006
    Plain'ol Texas
    553
    The Nitro Rustler rear arms are the ones you want. Most shops should have them on the parts wall.
    Dec 2009
    30
    Quote Originally Posted by majestic
    Thanks I'll give those a shot.
    Nov 2007
    Kansas City
    7,361
    The nitro arms are different. Any part marked with an x, is interchangeable with the part that is not marked with an x. The x is just upgraded.
    _
    _
    Dec 2009
    95
    Well... the part is not "interchangable" in all cases. For instance, on the Slash the stock battery hold down bracket is a 5827 and a 5827x is the holder for the use of larger batteries. While the 5827x fits in the truck it is not the same as the 5827.
    Nov 2007
    Kansas City
    7,361
    The parts are interchangeable, but they are not identical. There is a difference. You can replace 5827, with 5827x and they both fit.
    _
    _
    Dec 2009
    95
    Sure it will fit but it wouldn't do the same job as the original part. Your stock battery would slide around unless you wedged something in there. I mean, that's how it looks to me as I don't own the 5827x yet.
    I just wanted it to be clear that sometimes the "x" part is not simply "upgraded." Its different.
    Sep 2008
    Stockton, Ca.
    928
    This is correct
    Nov 2007
    Kansas City
    7,361
    They are all different , or else they wouldn't need a little x to pronounce them as different interchangeable means they will bolt in the same place. In the case of the battery strap, it still does the same job, and fits in the same place, therefore it is interchangeable. However, it does not mean it will work the best for situation.
    _
    _
    Oct 2002
    Ft Wayne, IN
    1,312
    Quote Originally Posted by Randopolis
    The extended battery kit has multiple locations for the batter bar to fit, including one that would be the same location as the stock one. Nothing would slide around at all.
    He is right, you are not.
    Slash PE, Slash 2wd, E-revo BE soon
    Sep 2009
    81
    it will work just make sure you have your grinder ready.
    http://monster.traxxas.com/showthread.php?t=501575
    Sep 2009
    St. Pete FLA
    543
    If the length is the same, a dremel will take care of the rest.
    Sep 2009
    90
    Looked at the other thread.. where someone actually did this.
    Here is the RPM part that will kinda work - 80182 (Black) and 80185 (Blue)
    http://monster.traxxas.com/showthrea...ht=Rustler+ARM
