+ Reply to Thread
Results 1 to 21 of 21
    Dec 2009
    7
    Exclamation 1/16 e-revo wheels and tires
    im getting the mrv for xmas wht size wheels fits it and where can i get some good looking ones. also is there a quick charger for the batteries so that it is not goin to take 6-8 hours to charge a battery. thanks for the help.
    E-revo21
    RC Turnbuckle Jr. Grand National's Avatar
    May 2009
    Southern Maryland
    3,037
    I run these wheels. They are great for pretty much every element. I go offroad fine with them, and are a bit taller than stock so they are great for top speed runs. A lot of people go with these tires. But there are so many options out there. Anything with a 12mm hex on it, will fit onto the 1/16 revo or slash. This means you can use rustler, stampede, jato, and bandit tires.
    As for the charger, many people will probably suggest this charger. Which will be perfect for the occasion once you buy a power supply. However, I went with the Onyx 230 charger, just for the fact it's a more "known" name and I could probably troubleshoot a problem if I have one. I love the onyx, it hasn't failed me yet *knock on wood*. The only downside to it is you need a external balancer to balance lipo cells. For a balancer, I went with the Astro Blinky Balancer. The setup is great, and the onyx 230 is proving to be a great charger.
    Hope I helped, you will love your mini revo .
    Casper - 2001 Dodge Cummins (my baby)
    Dec 2009
    7
    yeah that helped alot i love the looks of the car and im just amazed by the speed of it out of the box so pretty much i can use any 1/10 wheel cuz i like some of the touring wheels that the toyz have on their website. i heard that the charger it comes with takes like 6-8 hours to charge a battery and i was like thats a bunch of crap my mini t takes like 2 hours to charge so i want something thats goin to charge them batteries fast.
    May 2009
    Southern Maryland
    3,037
    Think about the chargers mentioned.The revo will just blow your mini t away. I've had both, and it's not even comparable. It will take 6 hours to charge, with isn't any good. I ditched the stock charger within 2 days .
    As for the wheels, you can't use all 1/10 wheels. The toyz mentions the rim's fitting. If it says the rim has a 12mm hex, then it will fit. If your interested in more larger tires, you can always install larger hex's. Some racers have put 17mm hex's to fit buggy tires onto their revo. A hex is the fitting that is molded into a rim, and fits in a hexagon shape installed onto the revo.
    These are what hex's look like. These are installed onto your revo, and the molding on the rim interlock with the hex onto the truck. You will see these once you get your truck, and it will all make sense.
    Dec 2009
    7
    thanks man your alot of help i cant wait to get my merv.
    May 2009
    Southern Maryland
    3,037
    No problem, feel free to contact me if you have any questions.
    Good Luck!
    Dec 2009
    7
    if i get this charger will it connect straight to the batteries or will i have to buy a connector and if so where can i get the right connector for the merv.http://www.horizonhobby.com/Products...ProdId=DYN4044
    May 2009
    Southern Maryland
    3,037
    That has a male Tamiya connector, which is what a lot of R/C's come with. If you go into Wal-Mart, most R/C's there will have this connector. With that being said, you need a Female Tamiya Connector to a Male TRX Connector. No problem, and I actually have one installed on my Onyx 230. This
    is what you need. That is a steep price for the connectors, but if you searched you should be able to find it at a better price. But it's what you need in order to use that charger for stock Powercell 1/16 Revo batteries.
    Dec 2009
    7
    ok cool i wish traxxas made a their own peak charging im just really weary about buying stuff that have connectors and stuff worrying that they wont fit and that i wasted my money im just new to rc and love it but it gets expensive quick if your not careful. how long do you thing that charger i picked out would take to charge a battery.
    Dec 2009
    7
    i guess this charger would work then i wouldnt have to buy the connector
    Oct 2008
    247
    rear: slicks.
    front: oversized 1:10 monster wheels
    center diff takes care of the size difference
    E-Revo,700HO/Novak5.5,5Ah LiPos
    Baja 5B SS
    MERV
    May 2009
    Southern Maryland
    3,037
    Quote Originally Posted by qorron
    rear: slicks.
    You put your front left tire on backwards pal
    May 2009
    Southern Maryland
    3,037
    You could do that, Horizon Hobby has great customer service.
    Not a bad option to go for.
    Nov 2009
    UK
    838
    would the traxxas revo wheel nuts fit the mini e revo?
    i have some jato wheels, but i have to screw the nut on real tight until you hear plastic creak, otherwise (for me at least) the nut will come lose after some time and the wheel will fly off. it's happened to me 3 times, two high speed, one just after a jump.
    Rockford IL
    168
    From the looks of it, any 2.2 inch wheel/tire combo will work as long as the wheels are 12mm hex. Right?
    'Brushless...RCs Magnacharger'
    Dec 2008
    Melbourne Aus
    1,925
    Correct Subiefan
    Just be careful some 12mm hex wheels fit but have a larger hole designed for a larger diameter axle, and some may not have clearance to allow you to tighten the nut far enough
    Revo wheel nuts are 17mm Hex and will not fit
    Cheers
    Slash Platinum
    SCT MMP / 2400kv
    Mar 2009
    Alabama
    646
    I went with the jconcepts on double dees
    Slash 4x4 VXL
    Mini Revo VXL
    Rustler VXL
    Micro-T
    4
    Quote Originally Posted by qorron View Post
    rear: slicks.
    ^^^Where can i get some of these!?^^^
    - the front tires that is.
    so cal
    9,245
    where did you find that old thread!
    Saskatoon Saskatchewan Canada
    112
    I want to bring this back from the dead too!
    Has anyone run a set of these?
    Found them on the Integy site.
