+ Reply to Thread
Results 1 to 14 of 14
    Sep 2009
    Far upper west Kentucky
    150
    Slash VXL and ABS...
    Quick question before getting back to work.
    I have a Slash with a VXL brushless system in it. Just rebuilt new trans in it, and tested it today at lunch... Works great, a little undergeared...
    BUT... On my new radio, I decided to try out the ABS... It worked pretty darn good, only drawback that I saw was that it will "pulse" reverse after it stops. (And that it seems to run the battery down a little quicker, but not bad)
    Today, I ran a 7 cell, 5000 Mah battery, and used full throttle and ABS as much as I could, and the motor was barely even warm after 20 minutes. I mean I could BARELY feel any warmness...
    So, I going to gear it up some, (21t/83t now) but...
    QUESTION... Will ABS hurt the ESC, or the motor? Seemed to do fine, but it's still pulsing the motor. It's not putting it in reverse till the truck stops, but it is pulsing reverse as soon as the truck stops...
    EDIT: BTW... On pavement, ABS worked great... I could brake powerslide if I wanted to, but straight line breaking, no lock ups or unintentional brake slides... It did take a little longer distance to stop, but on the other hand, I can now go into a hard turn so much faster now since the rear end isn't locking up and sliding.
    Haven't tried it in the park / gravel / dirt yet...
    Slash VXL+Lipo=Zoom Zoom Zoom!!!
    Nov 2009
    Kelowna, BC Canada
    206
    Is that ABS, as in Anti-Lock Brakes? If it is I had no idea that could be done...
    Jul 2007
    KY
    148
    I haven't tried it on my slash, but works great on my 8T and Slayer!
    8ight B2.0,8ight T2.0,XXXSC,Rustler,Micro T and B
    Aug 2008
    32
    Auto Brake System
    Traxxas for ever :)
    Oct 2007
    1,773
    do you mean drag break?
    St. Louis, MO
    655
    That is the best idea ever. Is the pulse rate adjustable?
    Dec 2007
    lansing ks
    1,470
    most radios that have it have a low mid and a high abs setting
    Sep 2006
    Marietta, OH
    3,073
    Quote Originally Posted by schofield
    No, ABS like on a car. It pulses the brake signal to keeps the brakes from locking up.
    Those who throw dirt are bound to lose ground.
    Oct 2007
    1,773
    Quote Originally Posted by aussiek2000
    right got it.
    Sep 2009
    150
    Yes, Auto Brake system like a car, but it can't sense if you lock the brakes, it can only pulse the brakes low, normal, or fast...
    But, either in the slash manual, or the radio manual, it did say not to use ABS with the ESC...
    But it works so good!!!!
    Now, I don't think I would have a bit of a problem if I set the ESC to forward only with brakes... It's just a little weird how it also pulses reverse after truck stops completely. Pulsed reverse is only like 2 MPH!
    Like I said, ESC or motor did not even get warm...
    Sep 2006
    Marietta, OH
    3,073
    FYI, it stands for Anti-lock brake system, not auto brake system.
    Apr 2009
    555
    its really not ment for electric !!! its ment for nitro or 1/5th scale cars i wouldent used it on electric , if you read your book that comes with most BL systems it tells you to disable the ABS on the radio , and i think thay tell you that for a reason!!!!!!!!!!!!!!
    IF YOU CANT FIX IT DONT BUY IT !
    Jun 2009
    Western australia
    514
    Quote Originally Posted by jaysd200
    yes this is true.... i would disable it if i where you.
    GARAGE
    e-revo, ME-revo, micro-t, slash, DX3S
    Sep 2009
    150
    OK...ok... I turned it back off...
    I did adjust the braking end point to barely lock up the brakes, and it's much better than it was...
