I was woundering what i need to install 2.2 rims on the jato, size of spacers or anything i need to install them.
i put the lightweight dished wheels on no problem. on the front make sure you put both bearings in the rim and the spacer on the inside. hope this helps
Direct fit, nothing else needed.
However, make sure you buy 2.2 wheels to fit the Jato and a second set of wheel bearings and front wheel bearing spacers are handy - saves swapping bearings /spacers when you swap wheels
JATO 3.3 - On Steroids!!
Revo... What Revo?
