    Jul 2009
    Oktoberfest, Munich
    217
    alu turnbuckles / pushrods
    so i was looking for some spare pushrods (turnbuckle is just another name?!?) and only found these 3 options:
    on the first two
    http://www3.towerhobbies.com/cgi-bin...&I=LXHFV8&P=OW
    and
    http://www3.towerhobbies.com/cgi-bin...&I=LXHFW0&P=OW
    it says "only use with p1 / p2 rockers"
    and on the 3rd
    it says nothing like it...
    question: since i run the stock p2 rockers which of them can i use?
    do i always need a special set?e.g. when i buy p1/p3 rockers i definetly NEED a special pair of pushrods for each?
    erevo mmm-need mip pins...
    slash pe
    Dec 2008
    Scotland, UK
    61
    For P2 pushrods you'll need the 5318X - http://www3.towerhobbies.com/cgi-bin...?&I=LXHFV8&P=M and re-use the blue spacers from your stock pushrods, or buy the red spacers- http://www3.towerhobbies.com/cgi-bin...?&I=LXHRB8&P=M
    P1 and LT rockers also use the same pushrods, for P3 rockers use the 5319X alu pushrods.
    Turnbuckles are for the steering and rear toe links and are adjustable, 2 sets needed if you're not using RPM true tracks on the rear which eliminate the need for the toe link/turnbuckles.
    http://www3.towerhobbies.com/cgi-bin...?&I=LXKYC7&P=M
    Jul 2009
    Oktoberfest, Munich
    217
    in fact i will go for the rpm trutracks in the rear...
    dont recall these spacers in the stock setup, though...havent seen my revo for 7 weeks, though
    slash pe
