+ Reply to Thread
Thread: throttle servo
    Apr 2009
    red deer, ab, canada
    92
    throttle servo
    i just got done putting my throttle servo back in and i can't remember for the life of me if the stopper on the linkage is supposed to touch the servo horn or not. if not how much space should i leave?
    Apr 2009
    Chicago Illinois
    402
    look at the exploded views.
    Apr 2009
    Detroit
    839
    Take your air filter off, and turn on your radio and receiver. Full throttle it and see if the carb is all the way open, and then adjust the linkage from there.
    Note:
    Under adjustment - the carb will not open all the way.
    Over adjustment - The chassis will flex
    Perfect adjustment - The carb will open all the way without the flex of the chassis.
    After that is set correctly set the return spring so the carb is returned to the idle position. Make sure the return spring have enough tension so the carb will not slip out of the idle position.
    Apr 2009
    92
    the exploded view shows where it goes not how far on it goes. thanks for the info
