+ Reply to Thread
    Sep 2008
    Edmonton, Alberta, Canada
    1,548
    How Should I Gear???
    As many of you know from my infamous "Got My Slash" thread, I'm dropping a 4s 9XL into it, along with some 2.2 Mashers and a motor fan. I got no clue what to gear this beast, and being that 5mm pinions are expensive, i wanna get it right the first time.
    What size pinion do you think i should get? I want around 50 mph, mostly driving in a thin grass field. Maybe I should get a really low one for jumps/small spaces.
    Jul 2009
    Aperture Laboratories
    2,450
    stock or 2 teeth lower is my guess
    greenwood cemetery bashplex 8°))
    10,179
    Anyone know what the final drive ratio is? That would help with suggestions I cant seem to find it. Maybe a traxxas employee can jump in?
    The stock spur/pinion ratio is 13/54. You can go as low as 9/58 if the 58 tooth will fit, and no clue how high. I am sure you could get some revo mod 1 gears in there.
    LETS GO PENS!!!!
    Sep 2008
    1,548
    well i just ordered a 14t (summit) gear for messing around and a 25t for pavement-pounding, both 5mm.
    Sep 2008
    1,548
    as for ratio, i enter in the revo diffs on the speed calculator, with a tranny ratio of 1 (direct drive)
    10,179
    Did you figure out the final ratio?
    LETS GO PENS!!!!
    Sep 2008
    1,548
    no, but it will do 38mph on the speed calculator. that is about right
    USA
    3,040
    Quote Originally Posted by Super Dude
    Stock gearing will be very close to the VXL on 2s, but a tad higher in speed on the 9XL..
    not sure how big of a pinion you will need to get to your 50mph mark
    Sep 2008
    1,548
    Quote Originally Posted by filmmaker
    the speed calculator said around 18t, but i'll see how the 14t does speed/heat wise
