+ Reply to Thread
    187
    Quick Cheap knuckle FIX
    I don't know if this has been brought up, but for those of you saving up ur nickels & dimes for either the HR or GMP alloy knuckles here's a quick fix for the stock plastic ones. I had excessive play (about 3/4") on my left rear. Went down to the local Ace hrdwr store & got some O-rings 1/4OD 1/8ID. popped the retainer caps off & dropped the o-rings in & reinstalled the caps. no more play. sorry don't have pics. not sure how long it will last, only ran it one day before the weather turned.
    As fast as U can, & then a bit faster!
    Aug 2009
    Jersey
    899
    good idea.
    no binding from the rubber o-ring ?
    maybe a teflon washer can be used too ?
    ... just thinking out loud.
    Jun 2003
    Estes Park, CO
    863
    people have tried the teflon washer and it didnt really work too well cuz it's hard to find the right thickness
    Dye-no-mite Pow-er Go Fast, Wirrrrr Screeeech BOOM
    187
    didn't seem to bind, it is a little on tight side, but does seem to function fine. like i said only ran it one day. did break an a-arm on the right rear that day.
    Sep 2009
    Zimmerman, MN
    50
    The plastic that the retainer snaps into broke out of mine. I pushed it back in and filled the hole up with hot glue and it's holding fine until I can get the replacement knuckles.
    187
    Yeah i ran into that problem putting the o-rings in. but once they seated they were fine.
