I have seen erevos going past 80mph with a mmm esc and a nue motor on 6s lipo. Since the slash 4x4 has the same diffs and is like half the wieght how fast do you guys think it will go?
XO-1, E-Revo Dual 700-HO's, Slash 4x4, AX-10
Traxxas says 80+ mph with the 2200. You might be able to get away with running the 2650 because of the lighter car.
I was just wondering if it would go around 100 mph with a high kv nue motor.
I'm fairly sure the slash would take off and fly before it reached 100mph.
Been there, broken that.
only an insane person would try to hit 100 mph with a stock slash lolOriginally Posted by TrpleD
Without the body and different tires of course. I wonder who the crazy person will be to try to reach 100mph.
It will be hard to hit 100 due to the shape?
its a truck![]()
Originally Posted by Alex's Revo 3.3
Hmmm, ill try to get a 4x4 slash for next year.
World fastest E-revo 91.2mph / Revo 75mph
ABmods
This is a tough one. It may get to those speed, I have seen similar cars do that. Usually they are buggies, but this is very similar.
The biggest thing i've broken: My wallet.
We tried to get some top speed with the SC8e , with a Neu 1515 1.5d, we hit 78mph as best at like half throttle, it was always taking off at that speed.
The body just act like a parachute, the front skid plate didnt helped too...
We will see with the Slash, it may be different.
ABmods
you would probably need a custom front spoiler or something (some rusty people use bandit wings)
u'd a very very high downforce body, new tires, and several spoilers lol
Wide Rustler | "Bulldog" Backslash 4x4
maybe a few servos so when u hit 80 or 100mph u can pop out wings and fly awayu will end up with the worlds fastest flying (1/10) RC record.
+paddle tires for propulsion in the airOriginally Posted by brushlessbandit
i think making a prop. to add on the back of the center shaft would be more effective
good idea tho!
what about a erevo type body to help punch a hole through the air at these nutso speed?
My 2wd with a MMM and neu 2200 just flies into the air @ about 60 or so.No matter how I feather the throttle it just flies through the air. Mabye if you can get some downforce 2 wings 1 in front 1 in rear mabye. Too busy trying to break 100 with my erbe to really get into the slash just yet.Originally Posted by Alex's Revo 3.3
havnt failed I just found 1000 ways that wont work
u'd have to extend the shaft thru teh diff to do thatOriginally Posted by brushlessbandit
make a belt driven prop that comes directly off the motor lol.
we are really getting into this....![]()
i would be the insane person lolOriginally Posted by Super Dude
.................... if i had the money
mjw0625 on Xbox Live
Forza Motorsport 3 FTW!
100 mph is slow for an rc plane!!!Originally Posted by brushlessbandit
Drive it, Break it, Fix it, Love it, Repeat
but not for a flying short course truckOriginally Posted by TrickTraxxas3
So what do you guys think the best neu motor will be if I wanted to use it with a erevo and a slash 4x4? Something 6s capable. Also what esc?
the slash is light, but the revo is definately not so you would probably be better off with the neu 1515 1.5d(this is the same size as the 2200 but has 2700kv) or the castle 2200 with a monster mamba.
the pro will probably be too small for the revo. either way, try to get the highest C rated battery you can afford regarding the revo. the larger trucks can sometimes draw in excess of 200A on a hard launch so you need a decent C rated pack or it won't last long.
I would recommend atleast 25C on a revo since some companies inflate their c rating and there is really no standard for testing.
ERBE, 8ight, 8ight-t, b4,b44, scte, slash 4x4
So what is the difference between a neu 2200kv and a mamba monster 2200kv.
It says the 1515 1.5d only has a 22 volts max. What about the 1515 1y it has a 27 volt limit.
the neu 2200 has large vent holes in the can and is hand made. some claim it to be a little more effecient, but i don't think so.(i've had both) i'd go with the castle 2200 as it has a sealed can.
the 1.5d shouldn't exceed 22 volts, but many many have including me. you just have to watch your temps![]()
So is the a big difference in speed between the mamba and the neu?
no. i've found the hand wound neu (the neu 1515 1Y 2200) and the monster mamba 2200 to be identical in speed.
Ok thanks. What about an esc. Should I just get a v3 mmm
yeah, or a tekin RX8 is also an excellent choice.Originally Posted by Alex's Revo 3.3
K thanks a bunch
How do I tell the difference between a v1 v2 and v3 mmm esc? I can't tell. Also where can I get one cheapest.
if you buy it from a large retailer, like tower, it will likely be the latest version.
I found one cheap but I can't tell if it's a v3. How can I tell by looking at it?
It should have a stamp that say V3 under the ESC if i remember...
mine is glued with double face tape on my RC8Te so i cant look..
ABmods
who will put our plan in action?Originally Posted by vxlkid
(volunteer to custom mod a diff, add a prop, and GAINT wings, in addition to putting it on a diet)
that would be the best flying SC truck ever. wait, the only one![]()
