Got a 2nd set of Rulux half-ups and Badlands because my first set wobbled badly. I figured I had torn the foam inserts when stretching them onto the wheel. So, the 2nd set I added yellow Ofna truggy foam inserts and was very careful mounting them. I cheated and used rubbing alcohol as lube, to make sure I didn't bend up the wheel or tear the foam. It made each wheel about a 2 minute job. Anyway... I then spent another hour trying to get them not to wobble. I tried everything. As I was using the air compressor to dry the rubbing alcohol, I noticed the tire would hold air pretty well. I "aired up" the tires through the vent holes I drilled and it seated the beads evenly. Even after that, I still have a little wobble. Nothing like before, but I'm still not satisfied. I plan to run the tires very fast before I glue them to see if that helps, but I don't have my brushless combo yet, and I took one of the titans apart to see what failed, so I can't. Oh, and it's not a balance issue. Anyone else have a better idea?
EDIT I mount the Badlands on the inner bead for a shorter sidewall. I tried the outer bead on one of the wheels just for S&G and got the same wobble.
