I think the ninth link is correct, but that is expensive. You can get good aluminum ones for that price.
-Brett
4wd Sportmaxx 3.3
Yes, the #9 is correct. They will need to be modified before installation though.
Dubro monster - 3mm hole, 3mm threads
There are 20 rod ends on the revo:
4 for the shocks - 3mm hole, 3mm threads (short body)
8 for pushrods - 3mm hole, 4mm threads
4 for toe links- 3mm hole, 4mm threads
4 for toe links- 3mm hole, 4mm threads LH
I have tried a few different alumninum rod ends and they all are worse than the Traxxas 5348 rod ends. FYI, the 5348 last much longer than the 5347 that come everywhere but the rear toe links.
The RC4WD rod ends are the same design as all the crappy ones I've tested. The cheap ones use steel balls on aluminum races. They get sloppy and the races fall out. They aren't worth the price. The steely ones might work, but they're only available in male RH threads. It would take a lot to get them installed.
I finally found some halfway decent looking aluminum rod ends from RC Channel. They use brass races which is a much better material for this application. There are two races per rod end, and they pop out too easy (same problem as the cheaper rod ends). I removed all the races and reinstalled them with green loctite. Then I drilled and tapped them for the various locations. Last weekend, I replaced all 5 rod ends on the front right with the RC Channel ones and all the rod ends on the front left with 5348's. After a few weeks of testing, I'll know how they last.
If you plan to use aluminum rod ends on either the front or rear toe links, you will need something to stop them from rotating freely. Because it's metal on metal and there is no torque applied, nothing prevents the toe links from rotating and adjusting your toe by several degrees. I use Vibra Tite for this. You can get it individual sizes or in a bottle.
really thanks chetOriginally Posted by chet jamio
this was what i was looking for:
so i'm still undecided between this 2Dubro monster - 3mm hole, 3mm threads
4-40
3mm
beacause i don't understand what mean 4-40.
do you think i can easily modify the 3mm threads to 4mm?
i mean, just screw them on the pushrods/turnbuckles to enlarge the threads?
same question for modify from 3mm threads RH to 4mm threads LH.. just screw them on the turnbuckles?
about alu rod ends, what chet said definitely conviced me to use the plastic ones.
too strange to live, to weird to die
4-40 is a SAE thread type, not metric. You don't want those.Originally Posted by dr_gonzo
FYI, it's a thread with .112" outer diameter and 40 threads per inch. There's a goofy formula for the diameter. Multiply the first number by .013 and add .060.
4 x .013 + .060 = .112" (2.8 mm)
40 threads per inch = 0.635mm spacing between threads
If you were to write 4-40 in metric, it would be M2.8 x 0.635.
4mm threads are M4 x 0.7 which means they have a 4mm outer diameter and a 3.3mm inner diameter. You have two choices on how to make these:Originally Posted by dr_gonzo
1 - Plastic threads are typically just made as you install them. Just drill out the 3mm threads to some value between 3.3 and 4.0 mm. I usually aim for just below the average (3.65mm). Every plastic is different. I would start with 3.5mm (#28 or #29) drill bit. The benefit of this method is you don't have to do anything different for the RH or LH threads.
2 - Drill and tap them like you would with metal threads. You need a 3.3mm drill bit, M4 x 0.7 RH tap, and a M4 x 0.7 LH tap. With this method, you don't get the high friction fit you need for the toe links to prevent unwanted adjustments. In low strength plastics like we're using here, I've found this method to produce lower strength threads.
The RC4WD aluminum rod-ends are excellent...I run them on all of my crawler builds, and have used them on my Supermaxxes, and never had a single problem out of them. They are much higher quality than any other aluminum rod-end made.
Project: BL Revo Race Quad & BL G-Maxx G3R CF Revo
I bought golden horizons aluminum rod ends. We'll see..
Just play.
What about the RD Racing rod ends? They are made of T6-7075 aluminum and I hear their other products are great.
-Brett
4wd Sportmaxx 3.3
I have tested those too. Complete junk. Lasted about 2 battery packs.Originally Posted by Pulse
The best shock rod ends I have found are the Racers Edge ends , the have a phenolic hollow ball that has stood up too a lot of bashing/racing .
At WARN 80% and climbing !
I am sure they are great, since everything they make is great.Originally Posted by carraig042
Already lasted 3 battery packs! Does that mean they're great?Originally Posted by chet jamio
Just kiddin' I prefer trying myself. We don't drive everybody the same way. If they brake I go back to the stockers and that's it.
Just play.
