Results 1 to 15 of 15
    Jul 2009
    536
    High turn vs Low turn brushed motor
    Can someone explain the difference between a higher turn and a lower turn brushed motor.
    Not the motors physical difference but the diffference in acceleration, run time, and top end speed.
    Thanks.
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,255
    Lower turn motors will have higher top speed but less torque or bottom end punch and shorter run times. Higher tun motors will have longer run time, more torque, but less top speed.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Oct 2007
    1,394
    What he said. Plus, the lower turn motors are often more expensive and wear out faster (brushes + lots of heat)
    Two Rusty VXLs, M2Ks 18/83 - Tag! You're it!
    Sep 2008
    Bonnie Scotland
    643
    Not to complicate things, but it's worth noting that this is a rule of thumb that applys to motors identical in every other way. A generic rule as such.
    You can get some 27turn motors for example that will out perform some 19 turn motors in both acceleration and top speed
    I was born to break the mould
    RC Turnbuckle Jr. Emaxx2.0's Avatar
    Sep 2008
    West Palm Beach Fl
    4,079
    Quote Originally Posted by Hardcoretam
    This is correct. Gearing is more important on a brush motor then a brushless. A correctly geared 27t will out proform a incorrectly geared mod.
    Simply the best. The beautiful Traxxas SRT and TCP
    SAINT CHARLES, MO
    2,314
    what is the real difference in high kv motors vs low kv motors?
    EMAXX-x2,SUMMIT
    RUSTLER VXL
    FERRITE RINGS PM ME!
    Sep 2008
    Bonnie Scotland
    643
    Quote Originally Posted by akrimmel
    kv represents rpm per volt in Brushless motors.
    a 1000kv motor, will mean the motor will attempt to reach an RPM of 1000 every 1 volt it gets.
    7.2volt battery and a traxxas vxl motor (approx 3400kv) = 7.2 x 3400 = 24480rpm
    if both motors are equal in size and equal power source for each, then as a general rule it would be
    Low kv
    more torque, less speed, cooler running and longer battery times.
    High kv
    High speeds, more power, less torque, hotter running and shorter battery times
    SAINT CHARLES, MO
    2,314
    so same as high turn vs low turn motors then?
    EMAXX-x2,SUMMIT
    RUSTLER VXL
    Sep 2008
    Bonnie Scotland
    643
    pretty much, except the opposite way around
    Low kv brushless = high turn brushed
    High kv brushless = low turn brushed
    Jul 2009
    Aperture Laboratories
    2,450
    Low kv
    High kv
    not completely true. high and low kv motors can produce as the same torque, but the higher kv motor will make more RPM's, draw more current and run hotter than a low kv motor GEARED THE SAME. if you gear the low kv motor higher you can go the same speed as a higher kv motor geared lower. so its not the same thing as brushed motors. you can always gear a low kv motor to have similar speed, temperature, and draw similar amounts of current. vice versa.
    this is confusing but i hope it helps.
    Sep 2008
    West Palm Beach Fl
    4,079
    Quote Originally Posted by brushlessbandit
    When applied to sensorless motors. Sensored base motors behave more like brush motors. Noticed crawlers use 21.5t or 17.5t sensored motors for torque (of course lower rpm).
    Sep 2008
    Bonnie Scotland
    643
    on the same battery, that is not corrent.
    I have a 540 1000kv crawling motor. If i gear it too high it cogs like crazy and won't move. it can't be geared to run anymore than about 10mph in my Axial
    Jul 2009
    2,450
    i thought you meant sensorless
    Quote Originally Posted by Emaxx2.0
    Sep 2008
    West Palm Beach Fl
    4,079
    like emax2.0 said sensored motors are used in rock crawlers i thought you meant sensorless
    No, I was describing how lower kv=more torque ,higher kv= less torque mostly applies to sensored base motors, not sensorless. A crawlers' motor would be a 21.5t or a 17.5t for the amount of low end torque(plus it's alot more controllable and of course low rpms).
    Sep 2008
    Bonnie Scotland
    643
    Unfortunatily my 1000kv motor is sensorless
    It really goes suck in my crawler. It cogs under very big load even when geared down for about 3mph top end
