+ Reply to Thread
    Mar 2009
    7
    Spur gear striped
    My mini erevo is so powerful it can flip 2 circles on the air. I use lipo and have some questions
    should i reduce the pinion?
    is there a cnc spur gear available?
    many thanks
    Jul 2008
    Chicago
    5,114
    Quote Originally Posted by minime388
    GOT_VIDEO?
    should i reduce the pinion? is there a cnc spur gear available? many thanks
    If you "reduce" the pinion (put a shorter pinion on) it's going to loose top speed but gain torque.
    As far as a alloy spur i don't recommend it. You want to keep it plastic (spur) as the "weak link" in the drive train. You dont want to be blowing out diffs or drive shafts before the spur goes (although some have with the stock plastic spur)...
    Keep flex'in those forum keyboard muscles.
    Mar 2009
    7
    hehe no i don't have video but it's true.
    I think cnc delrin spur gear will be better?
    Jul 2009
    115
    Something will break as nitro said. You want the weakest link to be the cheapest and easiest part to replace. If you do put Alum. on it, you had better loosen up the slipper a little bit.
    Jun 2009
    Western australia
    514
    what are you running it on? 4s. if so go down to a 3s or just run your 2s in parallel
    GARAGE
    e-revo, ME-revo, micro-t, slash, DX3S
