I just got my Sidewinder with my Vxl up and running today and the glitching is horrible. If I were to say buy the Tower Hobbies 2.4ghz radio will the problems go away completely?
Vehicle(s): None
Owned:Rustler,Slash,E-Maxx
Of course any 2.4 radio/receiver is better than stock, but describe your glitching. What is/isn't it doing? Just asking, everything hooked up correctly? No shorts of any kind?Originally Posted by liam
Jammin' Nitro Truggy 1/8
Slash 1/10
Slash 1/16
The servo will go crazy and the motor will jerk a lot until it gets into range. Also are they're any other solutions to this kind of problem because I don't have the money to shell out right now for a new radio.
Vehicle(s): None
sounds like you are suffering radio interference from the brushless motor.
i have a mini lst that did the same thing. i had a decent am radio in it and installed a mamba micro pro system into it and it glitched like mad, i put a fm radio into it and all the glitching quit.
just my .02
Slash, Not Stock Anymore...
K, thanks I'll try that.
Vehicle(s): None
Braiding the wires between the ESC and the motor sometimes helps as well.
BlindMan Racing
Rusty - MERV - Pede 4x4-QR-1
SPC Lipo Power
and if you get a new 2.4 go with the new one called the off roader, it is like 80$ with 3 channel and 15 model memory and the recivers are only like 30$....
2 vxl slash's
vxl mini slash
comp ax10.
go 2.4 that is what i am doing i am getting the tower one
Race-bred SSC 4x4
Durango DEX410
Hey 1slash your running the same system as I am are you having any glitching problems?
Vehicle(s): None
I was also getting a lot of glitching and interference with the xl-5 and it got worse when I went vxl. I got the tower hobbies 2.4 and it has taken care of all of that. I think it is a nice radio for the money but it is only the second one I have had the other was the Traxxas stock radio.
I'm sure there are better radios than this but for bashing around I think its good.
the one that bolibruch1 is talking bout is from RC4WD.
http://www.rc4wdstore.com/2/product_...roducts_id=616
im wondering if this is like the 3pm?!
Slash VXL | HPI Wheely King 4x4
Thanks, Kevin.
yea..AM Radios are complete crap...i've got an M11 that runs on FM at the moment and it works flawlessly...it's even got a built in fail safe so when i accidentally turn my controller off first instead of my ESC or unplug my barttery..my truck doesn't run away on me...(same thing when you go out of range)
I recommend an M11 if you're pocketbook can afford it..comes with many features..like ABS braking (no more balding tires when skidding to a stop)..traction control..among other things but those are the most important to me...as well when you feel like it..you can just swap out the FM Module and instantly upgrade to 2.4 Ghz..no more buying a whole transmitter..just a module and RX...which is just under $100 now
it does not how ever have telemetry...but meh I can live with out it...not really necessary for anything unless you're doing speed runs for soemthing..
also..the M11 has enough memory to keep the profiles of up to 30 RCs...
Fluttershy is best pony.
yes i was running my mini recever and it was relly glitcy but i just think it was a bad one so i am running the rusty one and it has been good but now hearing this i think it may be the sidewinder esc but it is not a bigy for me cuz i have a 2.4 on the way now!!Originally Posted by liam
Race-bred SSC 4x4
Durango DEX410
here's a tip...braid the wires of your motor...it should help with the glitching
??????? i don't get thatOriginally Posted by Fox
Race-bred SSC 4x4
Durango DEX410
Originally Posted by 1slash
iv'e seen other people do it and they said they've noticed an improvement in certain thins like glitching and the related..cuts down on resistance in the wires i heard too...but i'm not sure on that
Well right now I plan on using a .1mf capacitor on my motor and then for added precaution using ferrite ring.
Vehicle(s): None
My son and i are both using the TacTic 2.4 systems, and my son has a Castle Sidewinder with a 4600 kv motor in his Slash and he is having absolutly no problems what so ever. Also he has terrific range with it too.He can run it out as far as he can see it, and the signal is perfect. I would assume the Airtronics would be a good choice also as I have used their Radios in the past and have been pleased with them as well.
o ok i just did not know what wires to BradeOriginally Posted by Fox
Race-bred SSC 4x4
Durango DEX410
