Thread: Pinion Advice
    Jul 2009
    10
    Question Pinion Advice
    Hy
    Can enyone give me an advice which pinion is to be used by ...
    ... 2 NIMH parallel
    ... 2 NIMH seriel
    ... 2 2S LIPO parallel
    Thx for your help
    Feb 2009
    Sacramento
    1,861
    just run stock and watch your temps
    Apr 2009
    Wisconsin
    202
    Eeekk. Thats horrible advice. Use the stock 28t pinion for the 2 nimh parallel and 2s lipo parallel. Use the speed pinion which is the 23 tooth one for the 2 nimh series. I run a single 2s lipo and mine gets kinda of hot. I am thinking of using the 23 tooth pinion for that to lower my temps.
    Jul 2009
    10
    Thanks for your help POD87 ... and what's about the temp. any advice abouth the max. temp for engine and esc?
    Jun 2008
    Australia W.A Karratha
    2,374
    i would try and keep the motor at about 150 or less.
    rtr slash 4x4
    2s lipo
    some other rc stuff
    Registered User
    Apr 2008
    Bremerton, WA
    1,108
    An infrared temp gun is a very good investment. You can usually find them for less than $25, and it pays for itself if it saves just one motor or ESC.
    The magnets in the motor will loose their magnetisim if they get much over 220F. Temps of 150F on the outside can mean much warmer inside the can, so that is a good limit there. As for the ESC, 160F is really about as high as I like to see. Short term temps of 175F or so aren't going to immediately kill it, but higher temps shorten the life span of electronics. Much over 175F or so, though, and the thermal paste that glues the heat sink to the electronics can start to loosen.
