Results 1 to 20 of 20
    Mar 2009
    Namibia
    135
    Question Adapter or solder?
    I am getting some ***** batteries and was wondering whether it is better to get a deans to traxxas adapter, or to cut off the deans plugs and solder on traxxas ones?
    And a completely different question, but how long would a 2200Mah take to charge on this charger:
    http://www.*********.com/*********/s...Charge_Capable
    "Wow thats amazing! How much does it cost?"
    "oh"
    Jul 2008
    Chicago
    5,114
    IMO the TRX are better but mostly it's personal preference. It's probably easier to cut the battery deans off and replace them with TRX then to replace the ESC plugs to deans..
    Keep flex'in those forum keyboard muscles.
    Jul 2008
    Chicago
    5,114
    Quote Originally Posted by NitroNovice
    Any charger that will charge at 1c, or for that pack 2.2 volts will take about 1 hour.
    Apr 2007
    In a box on Hwy 64.2 - Bashin' With Mike, Pat & Brad. hey i didnt start this.
    7,488
    i would say just convert the packs. much less hassle. installing traxxas connectors takes a little patience. dont rush. take your time. much easier having all your vehicles run the same connector. right now im close to converting my plane to traxxas connectors.
    ADDICTED TO THE TWILIGHT SAGA
    Jul 2009
    Melbourne, Australia
    622
    Personal preference. For ease of use the TRX plugs are much easier to pulg/unplug but their bulkiness puts me off. They are just too chunky for my liking. They both handle about the same amount of current so whatever is easier for you.
    BASH. BREAK. FIX. REPEAT. ALWAYS REPEAT.
    Jun 2009
    Southern New Hampshire
    349
    That charger should be able to charge those batteries in an hour as it can charge at an amp rate of 1C. This means it will charge at 2.2 AMPS, not volts. Just and FYI
    HPI Savage LOSI Mini/MicroT, MRC Traxxas Revo VXL
    May 2009
    Southeast PA
    1,931
    The max amps of that charger is 2 amps. It charges through the balance tap and not the main power plug. It will charge 2 2S packs at the same time, but only 1 3S or 1 4S pack. At a 2 amp max charge rate it will take slightly over an hour to charge your packs.
    Jul 2008
    Chicago
    5,114
    Quote Originally Posted by Precision Man
    Thanks for the precision correction on "volts/amps".. It was early
    Jun 2009
    349
    In the early morning Volts and Amps seem to be one and the same. No worries.
    Mar 2009
    Namibia
    135
    Thanks for the input guys, I will go with the soldering. Is it a good idea to put heat shrink over the solder point, or is there some better way?
    "oh"
    Jul 2008
    Chicago
    5,114
    Thats the best way. Just a heads up, make sure you slide the tube on the wire before you solder it..
    Mar 2009
    Namibia
    135
    Quote Originally Posted by got_nitro
    I will try to remember that . Otherwise I might have a problem...
    "oh"
    Mar 2009
    Namibia
    135
    Another question about the charger linked in my first post. It comes with a cigarette lighter charge jack, so what do I need to plug it in to a wall socket
    "oh"
    Jul 2008
    Chicago
    5,114
    It's only a DC charger so you would need an external power supply. To be honest if you wanted to use a 12v power supply (like a car lighter jack) I wouldn't. I would cut the lighter jack of the wires and put some aligator clips on it and use the car battery directly..
    Mar 2009
    Namibia
    135
    Would an AC/DC adapter (such as those found on a laptop) not work?
    "oh"
    Sep 2008
    Stockton, Ca.
    928
    No need to put one on the Traxxas connector the solder point is inside the Traxxas connector. No exposed areas, no shrink tubing to rub and wear through and cause a short.
    Here's my ***** with the Deans style connector cut off and Traxxas solder on.
    [IMG][/IMG]
    Sep 2008
    Stockton, Ca.
    928
    If it outputs betwwen 9-15v and 5 amps it would work. Then you have to make a adapter to fit no biggie there
    or just get this
    http://www.*********.com/*********/s..._viewItem.asp?
    Mar 2009
    Namibia
    135
    Thanks again everyone!
    BTW radicalray, your link does not seem to work...
    "oh"
    Jun 2009
    349
    Radical is correct, make sure your power supply puts out somewhere between 9 and 15 volts, which, by the way, most laptop power supplies do not. My Dell puts out almost 20 volts, HPs and Lenovos also are around there so your laptop power supply may not work. Plus, they will probably not be able to push out enough amps.
    Just my 2 cents worth.
    Sep 2008
    Stockton, Ca.
    928
    [QUOTE=radicalray]If it outputs betwwen 9-15v and 5 amps it would work. Then you have to make a adapter to fit no biggie there
    Link fixed
    http://www.*********.com/*********/s...idProduct=6256
