Results 1 to 11 of 11
    Jun 2008
    london, city
    487
    ok chose charger and lipo
    ok i chose my lipo's and my charger now i just need to make sure there all compatible with each other and the revo 1/16, can any one make sur ei got this right?
    charger
    http://www.*********.com/*********/s...idProduct=7028
    battery x2
    http://www.*********.com/*********/s...idProduct=6540
    balencer
    http://www.*********.com/*********/s...idProduct=4176
    power supply
    http://www.*********.com/*********/s...idProduct=6879
    lipo sack
    http://www.*********.com/*********/s...idProduct=4364
    merv and erbe
    Jul 2004
    Ft. Smith, AR elevation: 449ft
    694
    this is not a balancer it is just a "monitor". it just watches you Lipo and tells you when it needs to be balanced...
    .___/ ```i____"""""""ex racer
    [_^______ ^ _]Now RCdrifter & Revo
    .( o )____( o )___Backyard basher
    Apr 2009
    crawley, UK
    208
    http://www.*********.com/*********/s...ncer_connector
    you will need a dual balancer board above for charging 2 x battery
    also get some extension leads
    http://www.*********.com/*********/s...nsion_2S_(20cm)
    you dont really need the lipo monitor as you wont be able to see it in the car
    Apr 2009
    crawley, UK
    208
    http://www.*********.com/*********/s...110/240v_Input
    This maybe better for you as entry level power supply and charger built together and should charge your batterys around an hour and a half each
    Apr 2009
    crawley, UK
    208
    OR 2x this from a single power supply
    http://cgi.ebay.co.uk/*******-LOW-CO...3A1%7C294%3A30
    Jun 2008
    london, city
    487
    Quote Originally Posted by tectic
    i will get the lipo moniter just to show me if it needs to be discharged and do i need a battery balencer with the charger you sent me a link of? and how do i use this charger do i plug the battery end in the 1 slot and the balencer end in the second slot?
    merv and erbe
    Jun 2008
    london, city
    487
    can any one please help me as i want to order it tonight
    merv and erbe
    Apr 2009
    crawley, UK
    208
    the balancer board is for the balance plugs on your lipos (the small white plugs)
    the power leads depending on what plug you choose deans or traxxas is connected to the charger through a charg lead you will need to make a y lead to connect 2 batteries
    Jun 2009
    24
    The monitor is a waste of $4
    The $12 ******* charger is a SLOW charger with balancer built in.. It's like 1/3 the speed of the $40 ******* you picked out..
    I suggest you stick with that ******* charger/discharger/balancer you picked... It's very cheap but has all of the features you want.. Charge, Discharge, Balance
    You can adjust the charge settings and it has a screen that displays all the info for you to see.. (not 100% accurate according to reviews but close enough)
    And it will charge each battery in about (usually less) than an hour safely.
    ******* is also a decent brand... It's unfortunate the power supply costs $40 also.. You don't need a power supply with that many amps tho.. You may find one cheaper elsewhere..
    Lipos are no joke.
    Read the manual when you get the charger it's very obvious what plugs in to what.. You may need to put on proper connectors but that's easy and your local hobby shop can help you.
    ********* has good customer support also..
    Oct 2008
    115
    Quote Originally Posted by revo madnesss
    I bought 4 of these before before I had my 1/16 Revo. Unfortunately the battery door cannot be closed all the way. You can secure the front clip, but these are just a bit too large to get the rear to clip to close.
    I've been running one of them this way, and the truck does rock on this pack. Instant backflips if you give it a handful, and wheelies are doable even at speed.
    Sep 2008
    Stockton, Ca.
    928
    charger
    battery x2
    power supply
    lipo sack
    You are good as your order is the battery monitor is not neccessary but hey its cheap
    You will need some Traxxas connectors for the batteries you can pick up locally or online
    http://www.*********.com/*********/store/uh_viewItem.asp?idProduct=7875
    http://www.maxamps.com/Traxxas-Parallel-Adapter-16.htm
    [IMG][IMG]http://i984.photobucket.com/albums/ae330/raybakker/*****3-2.jpg[/IMG][/IMG]
