+ Reply to Thread
Results 1 to 2 of 2
    Jul 2009
    rear belt tightening help
    Hi Peeps, I need some help to tighten my rear belt on my 4 tec. I saw how to do it on the site, which things to turn but i cannot maage to do it..not sure if there is something wrong with the car or its just me? Do you need to take the axle shaft off? I have laready taken it apart with no luck in it tightening...just as loose as when i started... please post here or email me at myzermoderator@hotmail.com
    thanks!
    May 2009
    33
    you need to take the diff off then take out the little oval that is inside the rear side plate ( you can see the ovals ring Im talking about and the side plates on this pics from towerhobbies : http://www3.towerhobbies.com/cgi-bin...?&I=LXNGE6&P=7 ) then you will see the adjustement, to tighthen it you will have to put the oval rings such that there is more plastic to the front, it s can of hard to explain just like this but you will get it when you ll see it !
    hope this helps !
