Results 1 to 27 of 27
    May 2009
    152
    Transmission demystified
    This is in response to the comments about swapping gears inside the tranny to further reduce final drive ratio.
    Jul 2004
    Ft. Smith, AR elevation: 449ft
    694
    i guess im wrong... it looks like it does fit
    .___/ ```i____"""""""ex racer
    [_^______ ^ _]Now RCdrifter & Revo
    .( o )____( o )___Backyard basher
    Jun 2006
    Seacoast, NH
    186
    so did you put it back together and try it out?
    May 2009
    152
    Quote Originally Posted by ProxyWRX
    No. I have a Slash. I don't have a need for reduction.
    It fits perfectly though. Almost like they planned it...
    EDIT: I guess I should say (since the pictures don't show it) that I did put all the gears in and held the shells together while spinning it. It DOES fit. I just did not install it in the truck.
    Dec 2006
    Genoa , IL.
    1,934
    Hmm I wonder how fast it would go like that ?
    At WARN 80% and climbing !
    Apr 2009
    211
    Wow, thank you for showing us this. Did you happen to count all the teeth so we can calculate the gear ratio change?
    Jul 2004
    694
    from counting the number of teeth from the pic...
    18 and 25 are the number of teeth for the gears that can be switched
    13 is the number of teeth of the other small (looks like metal) gear
    and the diff is 35 teeth
    now i could be wrong i was counting from the pics that he provided
    Apr 2009
    211
    Quote Originally Posted by konaman
    Duh, why didn't I think of that. Thanks.
    Southern New Hampshire
    349
    Small gear has 18 teeth and bigger gear has 25 teeth.
    You guys beat me to it.
    That will probably give it a max speed of about 20 mph with the stock pinion and battery.
    HPI Savage LOSI Mini/MicroT, MRC Traxxas Revo VXL
    Jul 2004
    694
    Quote Originally Posted by MuddyTire
    no problem... now its up to you to do the math i could but dont really feel like it...
    remember divide gears that are meshing and multiply ratios that are on the same axle.
    349
    Hey guys, guess what, Traxxas did build their tranny for that. If you look on the specs sheet for our little truck it specifies the internal gear ratio of the center tranny. It has two, 5.04:1, (reversed input: 9.72:1). That means that by reversing the internal gears you will get just over half the speed and almost twice the torque. They built it that way so that you could add really big tires. Just check out the manual where it talks about tires. Last paragraph on page 25.
    Jun 2008
    Brisbane Australia
    211
    What is that I can hear, is it a 1/16 summit comming MMMMMM!!!
    Jun 2008
    Brisbane Australia
    211
    That is awsome Peowraaku thank you for trying this!!
    Jul 2008
    297
    I have the original, first shipment of the slash. I still have the original slash tires (converted mine to use 1/8th scale tires)... they fit my revo. Maybe I should make a monster conversion.
    May 2009
    152
    all shafts are metal. all gears are plastic except for that small one, and it is part of the shaft. the whole thing spins VERY smoothly. i was quite impressed by the build quality. it was that clean when i opened it, and my truck has had the snot beat out of it. i was also impressed by the ceramic looking plate on the slipper. it looks like the brake rotor on a super car. does traxxas spec that material on all their vehicles?
    Jul 2004
    694
    that material is semi-metallic which is in all their "revo" spec slipper clutches if i remember right in the original advertisement for the nitro revo 2.5 they said its the same material that is in brake shoes for 1:1 cars
    May 2009
    152
    very cool, thanks for the response. i was away from the hobby when the revo came out.
    Feb 2009
    Smyrna TN
    321
    Are those plastic gears in there?
    Nov 2008
    NorCal
    30
    Fanatic1074 Are those plastic gears in there?
    Quote Originally Posted by Peowraaku
    Hi everyone, Im a newb!
    Feb 2009
    Smyrna TN
    321
    Hehe, sorry i guess thats what i get for skimming through the posts. thanks.
    Apr 2009
    Codova, TN
    861
    So did anyone try switching the gears to see what the speed ended up being?
    MMP-NEU 1112 1.5D 4S MERBE
    BEAST MODE [ON] OFF
    28
    Quote Originally Posted by Precision Man
    maybe this plus 4s lipo would make for cool running and purfect racing speed?
    May 2009
    111
    yea doing this and putting it on 4s it would prolly do about 30 and have tons of torque
    mini revo on order :)
    Jul 2008
    297
    Done thus, 4S A123 LiFePo4, motor was 146f and esc was 125f
    May 2009
    123
    Put on some Crawler Tires and maki it a Mini-Summit!
    Savage-Modified!, E-Revo VXL, Slash 2wd, Mini-T
    Apr 2009
    247
    Sorry for bringing back this old thread, but I had a question regarding the transmission 'underdrive' I just called traxxas and customer support says that the underdrive in the manual is referring to the spur pinion combo to compensate for the larger tires, but Im not buying it. So what I see here in the orignal post is what the underdrive gearing is?
    Also if the above is the underdrive gearing and I run 4" tires, do I just stick with the pinion I was previously running the the stock tires. Thanks for the help.
    ERBE... Best RC Ever!
    Apr 2009
    Codova, TN
    861
    Quote Originally Posted by cch1978
    did anyone, I guess I will have to try it!!!
    BEAST MODE [ON] OFF
