Results 1 to 3 of 3
Thread: Buggy Wheels
    Mar 2005
    Shawnee, KS
    149
    Buggy Wheels
    I have CRT.5 wheels and they seem to rub against the knuckle when intalled. The hex in the wheel is deeper than the hex on the truck. Is there some kind of trick to this or do I need to just run them to grind them down?
    Run it like you borrowed it!
    Apr 2009
    211
    I had the same issue with my Axial 2.2 rims. I ended up simply using a dremel tool and ground them off about 2 mm. See link for setup.
    http://monster.traxxas.com/showthread.php?t=480613
    Used the left(a) bit in this pic to do it. But b would work too I'm sure.
    Mar 2005
    Shawnee, KS
    149
    Is that what everyone else is doing or do I just bolt them on and wear them in?
