The wheels are Proline Commandos... not Cheyennes.
Just got mine back together with some 40 series Big Joe's and some new pint.
And it is an e-maxx, not e-revoOriginally Posted by nitrochulo
Pro-line hole shots on jconcepts rulus half offset.
Hpi phaltlines
My Fingers are sore, and my batteries are smokin!
What are the tallest/widest tires I can use with these? I would like something a bit bigger than the mashers or badlands.I have stock erbe tires and I want something bigger. I would like something around 6.5". The tread isn't really an issue and possibly like to get a set for street AND off-road.
SPECS: Outside Diameter: 3.82" (97mm)
Inside Diameter: 3.04" (77mm)
Width: 2.17" (55mm)
Hex: 17mm
Integy Monster On Road Master black.
ALways wondered about how well ca holds the tires on aluminum wheels? That concern, cost, and the likely hood of bending has always kept me from trying an aluminum wheel on my revo.Originally Posted by tectic
Okay so how please tell me how the heck did you get those 23mm Hex wheels to fit on the 17mm Hex Hub that comes with these trucks? I've been trying to find the right adapters/pins etc. to get some type of locking mechanism down so I could use them but to no avail. Please share your secret!Originally Posted by nitrochulo
PM Sent.
**I hope there are RCs in Heaven; EMBE + 6S FTW!**
He probably picked up a set of 23mm hubs?????
1/16 MERV
BL Revo Platinum MMM MADNESS!
^^^ I've tried umm all. I see that he seems to be using lock nuts instead of the Hex Hub locking cap that comes factory. Something is definitely different.
I am assuming the lock nuts hold the 23mm hexes on the axles.Originally Posted by makaveli72
These perhaps:Originally Posted by makaveli72
http://www3.towerhobbies.com/cgi-bin...?&I=LXNKS4&P=0
http://prolineracing.com/how-to-tips-23mm-hd-hex
(√) Zer0 tall-er-ance 4 stu-pid-it-deeeeee.
Im buying an ERBE next week and would like to know what I have to do to make my rims from my Revo 2.5 fit on the ERBE?
roadrage maxx on rulux rims, no offset
flux tires ( these have more grip than stockers imo )
Originally Posted by wheelman76
If the revo 2.5 uses the 5mm flanged nut, you just take the 17mm hex assembly off the ERBE and install the pin, 12mm hex, and 5mm flanged nut from the 2.5 on instead but you'll probably strip out the hex hub on the wheel if the MMM is anywhere near as powerfule as my Tekin RX8 and 2050kV T8 motor setup.
My car came with HoBao Dish wheel Part#86129 and Great Vigor Grass Tyres Part#MV3695S, as you can see they are low profile and the rolling diameter is lower, they work excellent on grass but were easlily damaged when used in rocky/gravel surface as side loading would pinch the bead against the rim and split the side of the tyre, the tyres bead mount the same way the Traxxas tyres mount so the HoBao rim could be an alternative and they have a 5 Spoke that look good aswell.
I have just fitted these Proline Badlands #1132-00 on to the Black RPM Revolver Stablemaxx rims #82302, they look awsome and have the same rolling diameter as the original Traxxas tyres as you can see in the photo, i think there may be a poofteenth in it if any, Im yet to try them out on grass to compare.
Q. do i need to drill holes in the RPM rims to allow air to flow in and out of the tyre?
next purchase will be the Chrome RPM Revolvers with Proline Mashers so I can do a few street runs and attempt the skate park if I can afford the damage lol!
I have those same rims and tires (RPM Badlands) and I love them too! Look great on mashers also
1/16 MERV
yeh they do look good, the photos just dont it justice IMO!!Originally Posted by Muggydude
did you drill holes in the rims or it works fine without them? whats their purpose as my othe HoBao rims have holes yet the RPM rims didnt, must be a tuning thing i guess.
I have had my Brushless E-REVO for about 3 weeks now and LOVE IT! Been running it with 2x 5000mah 2s 25c lipos. I have about 10 runs on it thus far. Picked myself up 2x 5000mah 3s 50c lipos today. I can not believe the difference. WOW! Unfortunately my truck felt the same way. Half way through my 1st run with these new packs, one of my stock front tires looked like a retread coming loose. I live in SC so I have been running it on loose clay, grass and mostly asphalt. To say the least, I am now in the market for some new tires even tho the other 3 still look fairly new. I have been out of the hobby for some time, so what I knew then isn't much help now. So I turn to more knowledgeable people for advise. I am looking at the Pro-Line Road Rage 3.8" (40 Series) Street Fr/Re (2) (stock # 1104-00) & a set of Axial 8-Spoke Oversize Wheel Chrome (stock # AX8009), will these work together?. I am wanting to maintain roughly the same size as the stock set-up. I want chrome wheels, not black chrome. I already have a set-up for running races on packed clay. So basically, I need a pavement / loose clay / grass set-up. Any advise would be greatly appreciated. Thanks in advance.
Or maybey I should just get another stock set-up perhaps??
Could really use the advise here, Thanks
You should make a new topic for that.
This one supposed to pics of tires and rims only, no discussions
Badlands and HPI 6-Spoke Black Rims
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNKS3
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJLG1
I like the way they look and they hook-up great, the tires seem to have a bit of roll to them. I think that is why people often go with the rolux rims.
Strange...... I went back and made sure I was in the right thread.....Originally Posted by Heuchemer
And the very 1st line of the thread is, and I quote "Ok so this thread is more for the new guys like me who have had a little trouble finding tire and rim combos."
Just looking for help....
Haven't been able to try it out yet (broken chassis - waiting with impatience for my KD-design aluminum chassis ;-)
Have new pinion and spur lying around to get back to original gear ratio (hope I have calculated right)... Uncertain how the ERBE will handle the increased weight...
LOSI FORCE WHEELS/2 CHROME 420-SERIES REVO
LOSI ROAD RASH ON-ROAD STREET TIRES AFTERSHOCK
All comments and gear ratio calculations welcomed.....
Erland the viking...![]()
Im also a NooBi to RC, and as awesome as this thread is with pics to proove the specified combo will work, I still just got into the habbit of reading on the manufactures sites for info on diamentions of rims and tyres, then with that info you will find out if the tyre/rim combo will work, in my limited experience i found the better the name/brand the easier it was to get size info for a match that im happy with plus i found that same combo in here anyways so i knew it worked and could purchase with confidence.Originally Posted by ZEALOUS_DRAGON
Anyways mate, if your wanting to maintain the same rolling diameter as standard then the 40 Series tyres are much bigger, so thats something to think about, there are plennty of pics in this thread with 40 Series for you to look at and consider.
I found out that the Axial 8 Spoke oversize rim will take any 40 Series Proline Tyre no worries, but the Road Rage your after will not work well on grass, personaly i would go for the Moab 3.8 #1117-00 or the Masher 40 #1105-00, either one of these should give you abit more grip on the grass as well as the road, or just settle for the road rage tyre for road fun and also invest in a set of Badlands 3.2 #1132-00 as i found out (see my comparison pics a couple posts up) the Badlands 3.2's have the same rolling diameter as the standard traxxas tyres it comes with...you can get the Masher 3.2 #1075-00, remember to consider if you require the 14mm hex or the 17mm hex too, I think it would be fair to say that theres not many combos this thread hasnt got pics of that will work/fit on an EREVO, so pic what you like, work out if you want to go as big as 40 Series, some people like it some dont, even people who have never tried them on their own car will have an opinion on that, if you have money to burn get what ever you like but if your tight then buy what is proven to work acording to this thread.
good luck,
Aus.
Edited for Language
-ksb51rl
With those wheels and tires, I'd go with the largest 68 T spur and a 16 T pinion.Originally Posted by Erland
It's been fun. See ya.
If I were you, I'd tone it down a bit with that KD chassis. They've been known to bend..Originally Posted by Erland
Not to mention that you may wait weeks, even months, before it arrives...
Ive got those tyres on axial oversize rims. I have used 18/68 gearing and it will go very hard.Originally Posted by Erland
I want to try 17/68 just for fun, just to see but i sort of think 16 could be too much as the tires are ok but not that grippy, you slide on 18 on moderate/hard acceleration.
Tape them if you can as the ballooning is insane.![]()
Not that great on the road and just slide on everything else but should last forever. Stock tyres are much grippier.
They are fun cos you can do huge slides under braking and all they other fun stuff low gip tyres offer....and wont blow up on full out 6S![]()
Heavy maybe, not that bad.
Temps are fine on road but if you try and go off road it will get very hot. All the spinning is not good im sure.
Hope it helps.
Can someone give me the link to the 17mm velocity white dish wheels?
^^^Originally Posted by nitrochulo
Originally Posted by ykndoit
^^^ Thanks all for lending me some help on this matter. What I needed for this to work on the EMBE were THESE (which I already had) and also THESE. I notice, I think it was the Traxxas CVDs which I recently got came with those locking nuts, but they are smooth and not 'serrated' like the ones linked to above. Just an FYI.Originally Posted by SlotterHouse
So yea, you basically have to lock the wheels in twice so they don't come off the axle. Thanks again guys.
EDIT: You also need axle pins...such as THESE.
Arrived in Norway in less than 3 weeks (which is not bad compared to any internet/ebay shopping across the sea) from order date so either I'm lucky and you wore notOriginally Posted by SlotterHouse
I'll definitely be looking out for bending but I see all kind off different feedback on that... Looks like KD has one group of fans and another not so positive... Not sure both group have tried it out and taken the investment though...
After 2 tail landings with broken rear hubs and last time even broken chassis I'm up for something else....![]()
I picked up an awesome looking set of tires but they have the 20mm hex. Is there any such adapter for the ERBE with 17mm hex to 20mm hex? Thanks
I think these will work, but the brown nut is reversed thread, so you'd have to get a couple regular threaded nuts to work.
http://www.stormerhobbies.com/cgi-bi...pl?pn=LOSB3510
Savage XL wheels , Terra pins tires. 17mm hex make it a direct bolt on
old thunder quake body :P
E-Revo MMM-2200 6s
Another hit to the assertion that an E-Revo can't look like a monster truck.Originally Posted by Foxprogt
I know they're having their break there by your brake drums. No, you're not invited.
What suspension setup do you have on that thing?Originally Posted by Foxprogt
1/16 MERV
