Results 1 to 25 of 25
    Jan 2008
    McKinney, Tx
    1,965
    E-revo Titan 775 and 700HO comparison
    Ok, so over in the e-maxx forum there's a lot of debate on the pro's and conns of each motor and which will be faster, better, and what have you... so i decided to do a quasi scientific test: Running around in a soccer field and semi wet baseball diamond...
    Here's phase 1.
    E-Revo
    Titan 775 18/68
    2x 2s ***** 20c lipos
    T-Maxx 6.3" tires
    Speed: 21.7mph (on pavement)
    In the field after 10min of WOT temp was 132F on the motor 112F on the esc. (outside temp is 77f)
    also after 10 min the *****s were down to 3.82v and since I forgot to bring the smart stop I decided to stop there.
    Phase 2: I'll put the 700HO in it tonight or tomorrow and do the same thing again and see how they compare for me.
    I will say this. This truck is a lot of fun with this setup!
    Mar 2007
    183
    Isn't 21 mph kind of slow for that setup? I thought the e-revo hit 30 with decent packs stock and I was under the impression that the titan 775 or the 700ho are both faster than stock.
    Jan 2008
    McKinney, Tx
    1,965
    Well i was kinda thinking that, but not sure. only had an emaxx with the twin titan 550s and it's been brushless for a few months so this still seems slow to me
    On the other hand I'm building this truck for mud and torque so speed is not an issue.
    Registered User
    132
    What did you use for the blue pice on your body clip? Fuel tubing or antenna? Thanks
    Luke
    Jan 2008
    McKinney, Tx
    1,965
    fuel tubing, makes it much easier.
    Jun 2003
    We-Go, Chicago, IL
    2,702
    What do you think of those tires? I've got a set on back order that I'm going to mount on 3.3 Revo rims.
    USA
    3,038
    21.7mph sounds like something is odd?
    Feb 2009
    4,902
    Maybe he has the batteries in parallel and not series?
    Project: BL Revo Race Quad & BL G-Maxx G3R CF Revo
    Jan 2008
    McKinney, Tx
    1,965
    I've been running those tires for almost a year now on my E-Maxx and they've been great. Two are getting a little out of balance now. Could be water but i dont' think so.
    Well unless there's something wrong with the EVX-2 they're in series.
    I've just been attributing the slowness to the fact that I'm used to brushless, could be the *****s. they're new and i've not run them in anything else yet. Tried them for a few minutes in the Stampede and they seemed ok.
    I've got the 700HO in it and it if stops raining by lunch time i'll try it again. and see if there's any difference.
    USA
    3,038
    21.7mph just sounds really low to me?
    Mar 2009
    314
    I just took my stock Summit out with some nice promatch packs and I got 21.0 mph flat. My wife's Revo smokes my Summit with the same packs. Seems kinda low to me too.
    We'll just have to see how the 700HO does.
    Summit, CEN MG10-TR, Losi Micro-T
    USA
    3,038
    So you got 21mph with the same motor in the Summit and it is geared lower than the revo?
    yep still sounds like 21.7 is slow?
    Jan 2008
    McKinney, Tx
    1,965
    Yeah but his tires are a lot taller. so you have to take that into account. his summit is geared what? 14t and 7" tall tires could be similar to 18t with 6" tall tires.
    Jan 2008
    McKinney, Tx
    1,965
    Here's phase 2.
    E-Revo
    KD 700HO 18/68 (single)
    T-Maxx 6.3" tires
    Speed: 26.1mph (on pavement)
    In the field after 10min of WOT temp was 162F on the motor 118F on the esc. (outside temp is 78F)
    Funny thing was temp on the outside of the can on the label side was 143, on the side without the label it was 112.
    after 10min the batts were at 3.78v
    I think they're pretty even on torque, obviously the 700ho is faster but runs hotter. Here in Texas in the summer, i'll probably run the Titan more for that very reason. It's also been mentioned that it takes the titans a few runs for the brushes to break in and they wake up.... it's also possible that these *****s are waking up. This is only their 4th cycle
    Hope this helps
    Mar 2009
    314
    When my Titan dies in my Summit, I'll most likely switch to the 700HO to try it out. I just got my 17t pinion in so we'll see what that does for my top speed tonight. I have my other thread where I'll post the results.
    86
    Thanks for taking the time to post the results of your research.
    I have been considering a 775.
    With the ho motor are you using just 2 of the leeds from the esc?
    Jan 2008
    McKinney, Tx
    1,965
    Quote Originally Posted by RICK_
    No problem. Yes but i want to replace them with either 4 or or larger gauge wire.
    86
    I was thinking you may have a current drop only using 2 of the 4.
    I think I read that some place.
    Off topic, are you a 1/1 Jeep guy too?
    Jan 2008
    McKinney, Tx
    1,965
    I was told that it doesnt...
    Yes, or well was. i'm Jeepless at the moment
    I had a '93 and her name was Tonka. But I'm holding out to get another next year!
    Feb 2009
    4,902
    I am a Jeep guys as well...XJs all the way!
    Jan 2009
    68
    Is it me or are both speeds slow? I got 28mph in my summit with 17t pinion and ***** 2s 5k.
    Jan 2008
    McKinney, Tx
    1,965
    Did you have the summit wheels and tires on? that'll give you a tad more speed as they are taller than the ones I'm running. by what almost an inch?
    I'm surprised there's as much difference in speed between the two motors though. i wouldn't think 1 turn difference would make that much difference.
    Jan 2009
    68
    Yes it was stock summit tires. I still think the revo should be faster with both motors?
    USA
    3,038
    Quote Originally Posted by tonkajeep34
    That's only 3/4" difference in tires, not alot taller..
    21mph sounds odd
    Jan 2008
    McKinney, Tx
    1,965
    I'll put the titan back in this weekend and see if it's any different... maybe i had the gear mesh too tight or something. but it sure didn't seem like it.
    And i agree that 3/4" is not that much but you have to remember that it's 12% taller so it will make a difference. (2.5" on the circumference) so more distance covered for the same RPMs.
    Again not saying that 21 isn't slow... it is. especially if you've just stopped driving any of my other trucks. but i'm not really sure it's that far off. There's a fellow over in the maxx forum that with this motor and a 21/68 only got 24mph... I'm running 18/68
