Results 1 to 16 of 16
Thread: Spur Gear Help
    Apr 2008
    moreno valley
    289
    Spur Gear Help
    I have been stripping spurs often and i was wondering about getting a aluminum one or just buy in bulk.
    I have the slipper clutch and gear mesh set good even took it too my hobby shop and they said it was good
    Please Help
    http://www.youtube.com/user/josephdelrio
    Jun 2008
    Delaware
    1,069
    Try tightening your transmission screws.....
    Feb 2009
    in my fox hole (Canada)
    1,124
    hm..is your pinion gear worn?
    has your tranny case been in any serious crashes? it might opf nocked something out of alignment..
    how're you stripping gears? after a jump?
    Fluttershy is best pony.
    Apr 2008
    moreno valley
    289
    all are tightened
    I thought it was so i put on the 23t pinion and it still stripped and yeah a srew ripped out of it when i missed a ramp
    no just driving.
    Greenwood Bashplex
    12,923
    search 32p on slash/rustler/stampede forums. I switched and have not had one problem since.
    Sit down, buckle up, hold on, pay me...
    Feb 2009
    here
    392
    +1 for 32p gears.
    ...true story.
    Apr 2008
    moreno valley
    289
    i can not find any threads on that? please help what is 32p
    Jan 2009
    Wisconsin...for now.
    455
    -1 for 32p.
    Setting the gear mesh should not be that difficult. My father has been racing for 14 years, I have been in the hobby for ~8 and neither have ever stripped a gear. All 48p, I cannot imagine ever having problems.
    United States Air Force
    At AFBMT..
    Apr 2008
    moreno valley
    289
    so instead of runnin 18t/86t i would run 17t/85t
    thank you for the help
    Jan 2008
    USA
    1,514
    Look into getting better motor mount screws. If those come loose in any way, you're going to get stripped spur gear. I too have never had a stripped gear so it is possible to run without stripping the gears. How do you set the mesh anyway out of curiosity?
    Apr 2007
    In a box on Hwy 64.2 - Bashin' With Mike, Pat & Brad. hey i didnt start this.
    7,488
    i run 32 pitch on alot of my vehicles. strip spurs alot less often.
    ADDICTED TO THE TWILIGHT SAGA
    Apr 2008
    moreno valley
    289
    i do it by look and wiggle and or the paper method.
    ok but i am asking if im running 18t/86t it would be 17/85t if it was 32p or 23t/86t would be 22t/85t if it was 32p correct
    Jan 2009
    Sheboygan, WI
    2,345
    Quote Originally Posted by josephdelrio
    Sorry, but some puncuation here would help alot!
    2 Stock Slashes
    2 Mod Slash VXLs
    Emaxx
    P4DE
    Dec 2008
    Florida
    1,066
    32 Pitch!!!!!
    I have monkeys dancing in my pants!!!
    Dec 2008
    Florida
    1,066
    No, to get 18/86 in 32p it would be 12/58, and 23/86 would be 15/58.
    Greenwood Bashplex
    12,923
    Here is a gear conversion chart. Find the gear ratio you are running now in the 48p chart. Go to the 32p chart and find a ratio as close a possible under 56 or 58 tooth spur. That is your starting point. A basic rule is if you go up or down 3 teeth in 48p, you will go up or down 2 teeth in 32p to get the same change in gearing. These gears cost about the same as the stockers. You need a jato spur (58 tooth or 56 tooth) and an (E-Maxx pinion). Robinson Racing Products also has 10 and 11 tooth pinions if you need to gear down further. I use 10,12,14/58 and is comparable to 15,18,21/86.
