    Apr 2009
    San Diego, CA
    171
    Venom Lipo balance charger
    Would this charger be ok for the ***** Lipos you guys were talking about?
    http://www3.towerhobbies.com/cgi-bin...&I=LXPZT6&P=BR
    Thanks.
    Apr 2009
    Codova, TN
    861
    I have the venom charger and also this charger http://www.*********.com/*********/s...idProduct=7028 it looks like the same charger, has the same setting only the backlight color is different
    Apr 2009
    San Diego, CA
    171
    So the one I pointed out should be ok then, right?
    Also, the 1/16 e-revo will only be able to handle one 11.1v Lipo, right?
    Thanks.
    Feb 2008
    76
    Quote Originally Posted by NCSDRacing
    Thanks.
    The ESC and motor will probably be able to handle a 14.8 lipo (since it handles 14.4 volts with nimh). However, the internal low voltage cutoff on the ESC is only for 2s and 3s lipos.
    Apr 2004
    Saskatchewan Canada
    855
    wrong, running 14.8V will put the esc into over voltage protection, it won't work, the max number of lipo cells you can run is 3 or 6 if they are wired in parallel, you are right about the low voltage just being for 2 or 3 cell lipos though
