    Apr 2009
    Pitt Meadows, BC,Can
    52
    my evx2 wont work.
    Well, went to go play with the summit, hit the button the ESC and they glitch like normal...
    And then nothing, esc shut off,
    I can only get a green, then a red light with the ESc unplugged from the reciever,So i took everything apart, and it worked, so i turned it off and on , off and on, and I was happy, working again!, Then put everything back in, and it wont work, it does nothing plugged into the reciever, but when i pull the wire, i et the green, then red light
    me very unhappy!
    Apr 2009
    52
    well, after some messing around, Ive fixed it! just went for a bash!
    anyways when I hook up my front lights up, the ESC shuts off, with out it hooked up, it works fine
    Registered User
    Nov 2007
    Farley's van down by the river
    875
    Check your servos, look for an abnormally warm or hot one. I had a bad one and that's how the Esc acted, lights would flicker then it shut off. Unplugging the bad servo would correct the problem...
    Nov 2008
    305
    i would also check the battery you are plugging into the bec side of the esc. I have one and when i plug it into the bec side it sometimes works and sometimes does not.
    Jan 2009
    68
    Is it just me or did nobody read his second post? It works fine without the front lights. Then it has to be the lights or wires going to them. I would look for a short in the wiring to the front lights, or check the resistance with a meter if you have one.
    Registered User
    Nov 2007
    875
    Quote Originally Posted by Zachandandy
    It may be the lights and it may not be, by disconnecting them you reduce the load on the bec which may keep it from shutting down but still not be the actual problem. I read the post, all of it. I also had a bad servo that caused the exact problem he is having therefore my suggestion of checking the servos is valid. There are others that have had bad servos also.
